gasket paper thickness
A question for the expert engineers.
Nobody seems to supply banjo gaskets for between  the late, heavy 1938/9 axle, so am going to make one.
First hurdle = where can I get gasket paper.......lucky.....first phone call,  to local very small factor..."yes I have two thicknesses - thick and thin,   13 inch X 13 inch sheets.  Took metric micrometer with me and found:-
Thin  = 3.5mm (0.013 inches - 13 thou)
Thick = 0.8mm (0.031 inches - 31 thou)
The make is anonymous.
Question....which thickness to use for banjo joint.....my thinking is the thick?
I will use the thin for the adjuster?
Ebay etc. would have involved a 1 week delay for delivery......already SEVERAL weeks delay on this axle alone waiting for bits!!!
Dennis
gasket paper thickness - by Dennis Nicholas - 16-09-2017, 12:44 PM
RE: gasket paper thickness - by Tony Betts - 16-09-2017, 01:32 PM
RE: gasket paper thickness - by Speedex750 - 16-09-2017, 04:35 PM
RE: gasket paper thickness - by Ruairidh Dunford - 16-09-2017, 06:06 PM
RE: gasket paper thickness - by Tony Betts - 16-09-2017, 07:33 PM
RE: gasket paper thickness - by Ruairidh Dunford - 16-09-2017, 07:36 PM
RE: gasket paper thickness - by Ian Williams - 16-09-2017, 07:51 PM
