A7 block
(21-09-2018, 05:00 PM)Tiger Wrote: Thanks Zeto
Would you be kind enough to check this for me !
To fit a +0.050” os bore
Standard size 2.2”
Plus re bore 0.050”
Bore size in mm.  2.250 x 25.4 =57.15
Using 57mm piston
Gap 0.15mm
Gap 0.006”
Is this too big or am I missing something
Regards
          Tim
Tim, as you have already calculated your bore is .006" too big to use 57 mm Pistons .
Are you sure the bore is .050 oversize, seems an odd size
A7 block - by Tiger - 21-09-2018, 07:49 AM
RE: A7 block - by Zetomagneto - 21-09-2018, 12:09 PM
RE: A7 block - by Tiger - 21-09-2018, 05:00 PM
RE: A7 block - by Zetomagneto - 21-09-2018, 05:29 PM
RE: A7 block - by Tony Betts - 21-09-2018, 05:43 PM
RE: A7 block - by Chris KC - 22-09-2018, 03:08 PM
