Timing gears /coil engine with noise
(20-09-2018, 10:56 AM)Austin in the Shed Wrote: What work have you done to the engine ?
If its a coil engine take the rectangular cover off the dynamo housing (Briefly) when its running to see if there is an adequate oil supply to the gears.
If you are using different timing gears/mismatched gears they could be noisy,but if they are cast iron (original gears) they will get more quiet when they bed together.If you have a high lift cam they will run noisier.
If this has just been bored/ new Pistons don't run on a test bench it will glaze the bores.
Timing gears /coil engine with noise - by borchi1 - 20-09-2018, 09:27 AM
RE: Timing gears /coil engine with noise - by Zetomagneto - 20-09-2018, 11:32 AM
