"cylinder head removal kit"
Sorry I sort of misread your post a bit, from your description, I should imagine the bottom half of a plug would be to tall so only the threaded section of the spark plug could be used, drill it out and tap it to say 10mm and weld in a peace of studding or lock in place with a nut then just use a flat plate with a hole in it across the head studs with nuts on and use a nut to tighten down on, then a couple of sharp taps with a soft mallet should work but I think I would use at least two of then to spread the load, sounds like a good idea, think I will knock up a couple with some plates. though shaped plates may be needed to clear the water inlets depending on the type of engine you have.
This may well work on a cast iron head, but not for a really tight aluminum head as it could strip out the plug threads.
"cylinder head removal kit" - by JonE - 17-09-2018, 09:43 PM
RE: "cylinder head removal kit" - by Chris KC - 17-09-2018, 09:50 PM
RE: "cylinder head removal kit" - by Hedd_Jones - 17-09-2018, 10:02 PM
RE: "cylinder head removal kit" - by Phil Kingdom - 17-09-2018, 10:10 PM
RE: "cylinder head removal kit" - by JonE - 17-09-2018, 10:17 PM
RE: "cylinder head removal kit" - by Hedd_Jones - 17-09-2018, 11:00 PM
RE: "cylinder head removal kit" - by Phil Kingdom - 17-09-2018, 11:12 PM
RE: "cylinder head removal kit" - by Colin Morgan - 17-09-2018, 11:16 PM
RE: "cylinder head removal kit" - by Ray White - 17-09-2018, 11:27 PM
RE: "cylinder head removal kit" - by Charles P - 18-09-2018, 12:09 AM
RE: "cylinder head removal kit" - by Andy Bennett - 18-09-2018, 06:40 AM
RE: "cylinder head removal kit" - by JonE - 18-09-2018, 08:45 AM
RE: "cylinder head removal kit" - by Dave Mann - 18-09-2018, 09:03 AM
RE: "cylinder head removal kit" - by JonE - 18-09-2018, 09:56 AM
RE: "cylinder head removal kit" - by Dave Mann - 19-09-2018, 08:28 PM
RE: "cylinder head removal kit" - by JonE - 19-09-2018, 06:17 PM
RE: "cylinder head removal kit" - by Colin Wilks - 19-09-2018, 08:13 PM
RE: "cylinder head removal kit" - by JonE - 29-09-2018, 04:02 PM
RE: "cylinder head removal kit" - by JonE - 30-09-2018, 03:51 PM
RE: "cylinder head removal kit" - by Chris KC - 30-09-2018, 05:39 PM
RE: "cylinder head removal kit" - by JonE - 22-03-2019, 07:32 PM
RE: "cylinder head removal kit" - by jansens - 22-03-2019, 07:45 PM
RE: "cylinder head removal kit" - by Hedd_Jones - 22-03-2019, 08:55 PM
RE: "cylinder head removal kit" - by Colin Wilks - 22-03-2019, 09:12 PM
RE: "cylinder head removal kit" - by Colin Reed - 23-03-2019, 01:12 AM
RE: "cylinder head removal kit" - by JonE - 23-03-2019, 10:03 AM
RE: "cylinder head removal kit" - by Stuart Giles - 23-03-2019, 12:45 PM
RE: "cylinder head removal kit" - by Ivor Hawkins - 23-03-2019, 05:28 PM
RE: "cylinder head removal kit" - by John Mason - 23-03-2019, 05:52 PM
RE: "cylinder head removal kit" - by Reckless Rat - 23-03-2019, 06:50 PM
RE: "cylinder head removal kit" - by Colin Reed - 23-03-2019, 08:49 PM
RE: "cylinder head removal kit" - by John Mason - 23-03-2019, 10:32 PM
RE: "cylinder head removal kit" - by Colin Wilks - 24-03-2019, 12:33 PM
RE: "cylinder head removal kit" - by Colin Ayre - 24-03-2019, 05:52 PM
RE: "cylinder head removal kit" - by Colin Morgan - 24-03-2019, 08:19 PM
RE: "cylinder head removal kit" - by John Mason - 24-03-2019, 09:14 PM
RE: "cylinder head removal kit" - by Chris KC - 25-03-2019, 04:03 AM
RE: "cylinder head removal kit" - by Andy Bennett - 25-03-2019, 09:05 AM
RE: "cylinder head removal kit" - by Colin Morgan - 25-03-2019, 12:45 PM
RE: "cylinder head removal kit" - by Chris KC - 26-03-2019, 12:46 AM
RE: "cylinder head removal kit" - by Hedd_Jones - 26-03-2019, 01:42 PM
RE: "cylinder head removal kit" - by Ivor Hawkins - 26-03-2019, 03:48 PM
RE: "cylinder head removal kit" - by JonE - 02-11-2019, 11:34 PM
RE: "cylinder head removal kit" - by Phil Kingdom - 03-11-2019, 01:16 AM
RE: "cylinder head removal kit" - by JonE - 03-11-2019, 10:23 AM
RE: "cylinder head removal kit" - by Colin Wilks - 03-11-2019, 11:11 AM
RE: "cylinder head removal kit" - by dickie65 - 03-11-2019, 02:14 PM
