17-09-2018, 10:11 AM
(16-09-2018, 05:52 PM)Reckless Rat Wrote: The Avons you should use have "Sidecar Triple Duty" on the sidewalls and have a different profile from normal motorcycle tyres, which are rounded. I used to use Avons but like the Longstones better. Mitas used to sell a tyre similar to the Longstones but Im not sure they are still available. Longstones recommend higher tyre pressures than Avons. I run mine at 30psi (1.8 bar). I saw a car loke yours at a local old car run. His was a 6 cylinder but basically the same.
Mitas tyres are available but the tread does not look like Longstone / Blockley to me and it's also marked as being a motorcycle tyre (Like the Avon SM...) https://www.vintagetyres.com/shop/tyres/...6&search=1
Wow..someone fitted a 6 cilinder to a Rosengart LR4N2?? he must either be a brave man of have done some hefty mods to chassis / suspension and braking as well.... would like to see more that BTW....
