Pinion Assembly
(17-09-2018, 08:28 AM)steve davidson Wrote:
(16-09-2018, 04:00 PM)Stuart Giles Wrote: Did you get the AC bearings from a bearing factor or similar? The ones Austin used on all but a few late cars are narrower on the outside race than the "off the peg" AC bearings. If  you have the standard width bearings, as well as that gap, the pinion mesh will be different by the difference in the width of one of the bearings.
The ones that Seven Workshop (and others) sell are ground down to the correct width.
https://www.theaustinsevenworkshop.com/p...-ac-thrust
Hi Stuart,  The bearings came from our Club supplier here in Queensland.  I think I'll pop the bearings back out for measure.  Thanks for the advice.
Hi Steve, the specially machined pair with narrow outer rings are held in the Melbourne Club Spares as Part Number 0394a - sold only as a pair.
Tony.
Pinion Assembly - by steve davidson - 16-09-2018, 09:25 AM
RE: Pinion Assembly - by Stuart Giles - 16-09-2018, 04:00 PM
RE: Pinion Assembly - by Tony Press - 16-09-2018, 11:47 PM
RE: Pinion Assembly - by steve davidson - 17-09-2018, 08:28 AM
RE: Pinion Assembly - by Tony Press - 17-09-2018, 09:21 AM
RE: Pinion Assembly - by steve davidson - 18-09-2018, 11:55 AM
RE: Pinion Assembly - by Chris KC - 18-09-2018, 04:39 PM
RE: Pinion Assembly - by steve davidson - 19-09-2018, 08:01 PM
RE: Pinion Assembly - by Chris KC - 20-09-2018, 07:39 AM
RE: Pinion Assembly - by steve davidson - 20-09-2018, 10:09 AM
RE: Pinion Assembly - by Tony Press - 21-09-2018, 07:27 AM
RE: Pinion Assembly - by Bob Culver - 17-09-2018, 01:45 AM
RE: Pinion Assembly - by Chris KC - 17-09-2018, 08:01 AM
RE: Pinion Assembly - by Robert Foreman - 17-09-2018, 08:25 AM
RE: Pinion Assembly - by Bob Culver - 17-09-2018, 10:56 AM
RE: Pinion Assembly - by steve davidson - 17-09-2018, 11:08 AM
RE: Pinion Assembly - by Bob Culver - 18-09-2018, 07:57 AM
RE: Pinion Assembly - by Bob Culver - 18-09-2018, 09:47 PM
