12-09-2018, 08:54 PM
I need to repair the battery box in my chummy as it's rusted through on the base.
It's a loose fit in the floor and just seems to hang off the flange at the top. However, when you try and lift it out it is restricted by the flanges on the seat support above.
Is there a trick I'm missing here or is it the case that the battery box was originally installed before the seat supports so can't be removed?
Grateful for any advice whilst in the meantime I remain baffled!...
