In the beginning
Hello chaps,
as I mentioned in another thread, here is where I/we want to start.
We decided to start rebuilding 2 chassis to a good rolling condition. As there are different ways of how to get through a project, we choose to start with the chassis for some reasons.
First of all is to see what parts we already have, what parts we need to repair or recondition, what parts we need to built and for what we have to pay buying new stuff.
As I said before, no animals or bodyshells were harmed for our project. We gatherd quite a bit of parts and this is where you guys come in. Due to the attachment-restrictions of 8 per post I´ll start with a few replies here with pictures of what we got. Right now there are 5 chassis in more or less good conditions. After going through a few spare parts lists we have a good clue on what parts we have, but not what kind of frames. They all look kind a similar with a few or less changes in the details. It would be nice if you guys could help us on identifying what exact kind of chassis we got and maybe from which years they might be.
Cheers, and thanks for your help in advance and again sorry if the grammar or spelling is somewhere wrong
Rob
This chassis was after our research part of a Saloon.
Front axle is missing but we have a few in stock.
One thing we noticed is that on the front spring the leafs are straight cut at the ends. We also have springs that are arrowed at the tips. Is that a sign for the year or the model?
Rear springs seem to have lost some of their clamps.
This one had been painted obviously and no chassisplate on it. Seems also to be with braking wires instead of links.
The next one had been worked on obviously. The rails at the rear seem to be cut off. Also is there a steel wire from"handbrake" going through the middle of the chassis. It apperas also to have the wired brake system due to the brackets that hold the small rollers at the rear traverse.
And then there are these following two.
I already asked for the traverse with the big holes in the middle of the frame. These two have it mounted off centre to the left. Also the holes in the frame made us wonder if these are LHD chassis. Speaking for this assume is that we also have a LHD steering column.
The shortend one with the axle imho is the oldest one. no noplate also but brakes with steel links. no wire there.
And here the shortend (oldest?) one:
In the beginning - by Colognerob - 12-09-2018, 12:05 AM
RE: In the beginning - by Bill Sheehan - 12-09-2018, 12:51 AM
RE: In the beginning - by Colognerob - 12-09-2018, 12:58 AM
RE: In the beginning - by Jeff Taylor - 12-09-2018, 10:31 AM
