Pinion shaft diameter
Roger, I think this is one of those topics where most of us are amateurs, and while we would gaily lash up our own axles we might hesitate to spout advice to others in view of the possible outcomes.
If you have either, there is sound advice in the 750 companion (Jack French, p169) or in Woodrow (section E4-13); also here http://www.vintageaustinservices.co.uk/page9.html - if you have not already consulted these sources I would strongly recommend doing so.
Looking only at your photo above, I'd venture that you aren't too far out. For my money I would try another increment of shimming, with the aim of moving the markings a little further toward the front of the car, and perhaps a fraction higher up the teeth? If the result then looks all wrong I would then go back to where you are and live with it. But I'm no expert...
One thing I would add is that it's hard to attain perfection with a part worn gear set. Above all else make sure it's all nice and free before you drive the car - any hint of tightness is likely to end in tears.
Pinion shaft diameter - by Roger - 26-08-2018, 09:39 AM
RE: Pinion shaft diameter - by Chris KC - 26-08-2018, 09:53 AM
RE: Pinion shaft diameter - by Roger - 26-08-2018, 10:04 AM
RE: Pinion shaft diameter - by Chris KC - 26-08-2018, 11:00 AM
RE: Pinion shaft diameter - by Roger - 26-08-2018, 07:27 PM
RE: Pinion shaft diameter - by Robert Leigh - 10-09-2018, 10:30 AM
RE: Pinion shaft diameter - by Bob Culver - 26-08-2018, 11:51 AM
RE: Pinion shaft diameter - by Stuart Giles - 26-08-2018, 04:46 PM
RE: Pinion shaft diameter - by Roger - 09-09-2018, 02:29 PM
RE: Pinion shaft diameter - by Bob Culver - 09-09-2018, 09:49 PM
RE: Pinion shaft diameter - by Chris KC - 10-09-2018, 05:29 PM
RE: Pinion shaft diameter - by Robert Leigh - 10-09-2018, 07:18 PM
RE: Pinion shaft diameter - by Roger - 10-09-2018, 08:21 PM
RE: Pinion shaft diameter - by Bob Culver - 10-09-2018, 08:53 PM
RE: Pinion shaft diameter - by Roger - 10-09-2018, 09:05 PM
RE: Pinion shaft diameter - by Bob Culver - 10-09-2018, 09:23 PM
RE: Pinion shaft diameter - by Roger - 10-09-2018, 10:35 PM
RE: Pinion shaft diameter - by Bob Culver - 11-09-2018, 10:57 AM
RE: Pinion shaft diameter - by Roger - 16-09-2018, 08:40 PM
RE: Pinion shaft diameter - by Tony Press - 16-10-2018, 12:37 AM
RE: Pinion shaft diameter - by Roger - 15-10-2018, 12:28 PM
RE: Pinion shaft diameter - by Roger - 16-10-2018, 08:48 AM
