Rod brakes rear axle
I also need to replace the seals in the rear hubs of this axle. Are they available?
Hi Ian,
The '38 axle seems to be in great shape, apart from the seals. Unlike the one presently on the car. I suppose I could convert it to cable brakes as a last resort? I have acquired a full set of semi girling brakes that I could use.
I'll put an ad on the forum for the short cross shaft parts and see what crops up.
Rod brakes rear axle - by Tony R - 13-09-2017, 05:44 PM
RE: Rod brakes rear axle - by Ian Williams - 13-09-2017, 08:30 PM
RE: Rod brakes rear axle - by Tony R - 13-09-2017, 08:32 PM
RE: Rod brakes rear axle - by James Anderson - 13-09-2017, 08:48 PM
RE: Rod brakes rear axle - by Ian Williams - 13-09-2017, 09:06 PM
RE: Rod brakes rear axle - by Tony R - 13-09-2017, 09:11 PM
RE: Rod brakes rear axle - by James Anderson - 13-09-2017, 10:12 PM
RE: Rod brakes rear axle - by totalshell - 16-09-2017, 09:33 PM
