Rod brakes rear axle
The rod system uses a half width cross shaft and a rod pivot on the rear crossmember, you will need to alter the cross shaft brackets too. I guess with some ingenuity one could cut up and alter the semi grilling cross shaft but that is probably as much work as fitting the correct parts...... that is if you can find them! I can post pictures if you really want to go down the route of fitting the later axle, but without the parts to hand is it really worth the trouble?
Rod brakes rear axle - by Tony R - 13-09-2017, 05:44 PM
RE: Rod brakes rear axle - by Ian Williams - 13-09-2017, 08:30 PM
RE: Rod brakes rear axle - by Tony R - 13-09-2017, 08:32 PM
RE: Rod brakes rear axle - by James Anderson - 13-09-2017, 08:48 PM
RE: Rod brakes rear axle - by Ian Williams - 13-09-2017, 09:06 PM
RE: Rod brakes rear axle - by Tony R - 13-09-2017, 09:11 PM
RE: Rod brakes rear axle - by James Anderson - 13-09-2017, 10:12 PM
RE: Rod brakes rear axle - by totalshell - 16-09-2017, 09:33 PM
