U joint woes help needed
And I agree with Ruairidh and Nick. Doing anything other is making a difficult job out of an easy one. Yes, a propshaft made by the local company will fit with some fettling (and I've obtained and fitted a fair few) but the dimensions will not quite be the same. Easy to do if you know what to do but why bother when David C sells propshafts that fit and work first time.
U joint woes help needed - by Erich - 28-08-2018, 09:30 PM
RE: U joint woes help needed - by john williams - 28-08-2018, 11:48 PM
RE: U joint woes help needed - by Erich - 29-08-2018, 03:47 AM
RE: U joint woes help needed - by Reckless Rat - 29-08-2018, 07:54 AM
RE: U joint woes help needed - by Jeff Taylor - 29-08-2018, 03:42 PM
RE: U joint woes help needed - by Roland Alcock - 29-08-2018, 04:41 PM
RE: U joint woes help needed - by Erich - 30-08-2018, 02:30 AM
RE: U joint woes help needed - by Peter Naulls - 30-08-2018, 08:08 AM
RE: U joint woes help needed - by Reckless Rat - 30-08-2018, 08:37 AM
RE: U joint woes help needed - by Jeff Taylor - 30-08-2018, 08:44 AM
RE: U joint woes help needed - by Erich - 31-08-2018, 02:08 AM
RE: U joint woes help needed - by Jeff Taylor - 31-08-2018, 09:08 AM
RE: U joint woes help needed - by Nick Turley - 31-08-2018, 11:44 AM
RE: U joint woes help needed - by Steve Jones - 31-08-2018, 01:59 PM
RE: U joint woes help needed - by Erich - 31-08-2018, 03:12 PM
RE: U joint woes help needed - by Erich - 01-09-2018, 06:08 AM
