U joint woes help needed
Erich,
Can you post a photo of your prop shaft and give us all the dimensions. If it were me I'd go for a complete new Hardy Spicer prop shaft and be done with it - speak with David Cochrane at Austin 7 Components - he may be able to have one of his new prop shafts altered to your specification or contact Bailey Morris quoting all dimensions - flange diameters, tube diameter, length between rear axle flange and gearbox flange, length of shaft with sliding splined yoke fully closed etc. and see what they suggest.
I'm sure Bailey Morris Ltd will be able to supply the correct size sliding splined yoke - see the link to their extensive parts catalogue below.
https://en.calameo.com/read/00261392802a87487be08
U joint woes help needed - by Erich - 28-08-2018, 09:30 PM
RE: U joint woes help needed - by john williams - 28-08-2018, 11:48 PM
RE: U joint woes help needed - by Erich - 29-08-2018, 03:47 AM
RE: U joint woes help needed - by Reckless Rat - 29-08-2018, 07:54 AM
RE: U joint woes help needed - by Jeff Taylor - 29-08-2018, 03:42 PM
RE: U joint woes help needed - by Roland Alcock - 29-08-2018, 04:41 PM
RE: U joint woes help needed - by Erich - 30-08-2018, 02:30 AM
RE: U joint woes help needed - by Peter Naulls - 30-08-2018, 08:08 AM
RE: U joint woes help needed - by Reckless Rat - 30-08-2018, 08:37 AM
RE: U joint woes help needed - by Jeff Taylor - 30-08-2018, 08:44 AM
RE: U joint woes help needed - by Erich - 31-08-2018, 02:08 AM
RE: U joint woes help needed - by Jeff Taylor - 31-08-2018, 09:08 AM
RE: U joint woes help needed - by Nick Turley - 31-08-2018, 11:44 AM
RE: U joint woes help needed - by Steve Jones - 31-08-2018, 01:59 PM
RE: U joint woes help needed - by Erich - 31-08-2018, 03:12 PM
RE: U joint woes help needed - by Erich - 01-09-2018, 06:08 AM
