crank bearing
Hi Tiger,
You should be able to tell from the engine number on the top of the crankcase above the starter motor. Look up the design changes for the exact number - but a number bigger than about M250,000 suggests a three bearing engine. Visually the three bearing crankcase has a bolt underneath the centre of the tappet chest that the two bearing doesn't. Cynics might also say that you'll know if it's three bearing by having a problem in a few weeks time! (Not necessarily true)
Dave
crank bearing - by Tiger - 31-08-2018, 06:21 AM
RE: crank bearing - by AustinWood - 31-08-2018, 07:52 AM
RE: crank bearing - by Speedex750 - 31-08-2018, 07:52 AM
RE: crank bearing - by Chris KC - 31-08-2018, 08:23 AM
RE: crank bearing - by Ruairidh Dunford - 31-08-2018, 08:27 AM
RE: crank bearing - by Chris KC - 31-08-2018, 08:54 AM
RE: crank bearing - by Ruairidh Dunford - 31-08-2018, 09:24 AM
RE: crank bearing - by Chris KC - 31-08-2018, 10:08 AM
RE: crank bearing - by Duncan Logan - 03-09-2018, 02:06 PM
RE: crank bearing - by Tiger - 31-08-2018, 10:15 AM
RE: crank bearing - by Robert Leigh - 31-08-2018, 12:30 PM
RE: crank bearing - by Hedd_Jones - 31-08-2018, 09:32 PM
RE: crank bearing - by Bob Culver - 05-09-2018, 11:10 AM
RE: crank bearing - by Chris KC - 05-09-2018, 12:05 PM
