Hydraulic brake conversion backplate
#41
(28-08-2018, 08:59 PM)Viteran Wrote: You could be correct, I did wonder if the bleed screw should ( logically) at the top so air would be expelled more effectively  but then The handbrake cables would also be above the back axle which seemed odd, but I suspect it could be correct for a hydraulic conversion and may explain my problems with the master cylinder if I am not bleeding effectively. When back home and under the Austin again I will investigate further. Hopefully someone on the forum with a Morris minor hydraulic. Conversion can give a definitive answer
Ian
The rear brake cylinders on my car are mounted so that the handbrake lever points downwards, i.e. the piston is pushed to the ground, this means that the inlet/outlet for the fluid is uppermost to ensure the complete bleeding of air. Mounted the other way up, air can be trapped. This is how they are fitted on Morris Minors, pointing downwards.
The orientation of the bleed nipple is independent of the wheel cylinder, but is best pointing upwards to allow air to rise to the highest point, as it is screwed into a banjo union it can be rotated to a convenient position.
There is a similar problem at the front, as one cylinder piston has to be pointing upwards, so that the inlet/outlet is at the bottom - effectively trapping a small quantity of air. Bleeding all the air out can be helped if the backplate is removed from the stub axle (remove hub first) and laid on its side and thus allow air a route out.
My brake shoe have the beehive spring and also a nylon spacer fitted between the back plate and the shoe to keep the shoe square to the drum, otherwise it could tilt the other way...
Hydraulic brake conversion backplate - by Mgibson - 05-02-2018, 09:17 PM
RE: Hydraulic brake conversion backplate - by GK5268 - 29-08-2018, 12:38 AM
