Smoking engine
#46
Hello all
The rings came from The Seven Workshop.The ones shown appeared to be made of black cast iron.They were gapped to 6thou. The rings needed either none of very little removed to correct the gap. The gap now is around 10thou indicating some bedding in has occurred. The other areas of missed wear are also in line with the website. The compression rings have bedded better but still show signs of a slightly triangular wear pattern, 3 high points. Wished I had thought of shining a light from below. The new rings are totally different. They are silver colour and machined on all faces with the two oil control rings of different construction. The bores are all round and still show some crosshatch pattern. I would like to state this is not a supplier complaint. I am only too happy to have the level of spares that our cherished supply us all with.
Adrian.
Smoking engine - by Adrian Payne - 02-07-2018, 09:00 PM
RE: Smoking engine - by Tony Press - 03-07-2018, 12:01 AM
RE: Smoking engine - by Chris KC - 03-07-2018, 07:55 AM
RE: Smoking engine - by Bob Culver - 03-07-2018, 08:22 AM
RE: Smoking engine - by Adrian Payne - 03-07-2018, 12:52 PM
RE: Smoking engine - by Charles P - 03-07-2018, 01:03 PM
RE: Smoking engine - by Chris KC - 03-07-2018, 01:19 PM
RE: Smoking engine - by Annaustin - 03-07-2018, 02:25 PM
RE: Smoking engine - by John Mason - 03-07-2018, 04:38 PM
RE: Smoking engine - by bystander - 03-07-2018, 07:20 PM
RE: Smoking engine - by Adrian Payne - 03-07-2018, 07:24 PM
RE: Smoking engine - by Chris KC - 03-07-2018, 07:47 PM
RE: Smoking engine - by Adrian Payne - 03-07-2018, 08:34 PM
RE: Smoking engine - by Ian Williams - 03-07-2018, 09:43 PM
RE: Smoking engine - by Adrian Payne - 03-07-2018, 09:58 PM
RE: Smoking engine - by Bob Culver - 03-07-2018, 10:30 PM
RE: Smoking engine - by 1938austin7 - 04-07-2018, 05:52 AM
RE: Smoking engine - by Bob Culver - 04-07-2018, 07:27 AM
RE: Smoking engine - by Colin Reed - 04-07-2018, 10:06 AM
RE: Smoking engine - by Ian Williams - 04-07-2018, 08:53 AM
RE: Smoking engine - by Adrian Payne - 04-07-2018, 12:43 PM
RE: Smoking engine - by GK5268 - 04-07-2018, 03:29 PM
RE: Smoking engine - by Chris KC - 04-07-2018, 03:38 PM
RE: Smoking engine - by GK5268 - 04-07-2018, 04:05 PM
RE: Smoking engine - by Chris KC - 04-07-2018, 05:50 PM
RE: Smoking engine - by GK5268 - 05-07-2018, 09:14 AM
RE: Smoking engine - by Ian Williams - 05-07-2018, 09:36 AM
RE: Smoking engine - by Chris KC - 05-07-2018, 11:52 AM
RE: Smoking engine - by fatcatvera - 05-07-2018, 01:48 PM
RE: Smoking engine - by Andy Bennett - 05-07-2018, 08:33 PM
RE: Smoking engine - by Chris KC - 05-07-2018, 10:15 PM
RE: Smoking engine - by GK5268 - 05-07-2018, 10:26 PM
RE: Smoking engine - by Andy Bennett - 06-07-2018, 08:49 AM
RE: Smoking engine - by Ian Williams - 06-07-2018, 10:42 AM
RE: Smoking engine - by Adrian Payne - 23-07-2018, 11:10 PM
RE: Smoking engine - by Ruairidh Dunford - 24-07-2018, 08:09 AM
RE: Smoking engine - by Adrian Payne - 24-07-2018, 10:39 PM
RE: Smoking engine - by Roland Alcock - 25-07-2018, 12:03 AM
RE: Smoking engine - by Adrian Payne - 26-08-2018, 05:32 PM
RE: Smoking engine - by Bob Culver - 26-08-2018, 08:57 PM
RE: Smoking engine - by Ian Williams - 26-08-2018, 09:09 PM
RE: Smoking engine - by Peter Naulls - 26-08-2018, 09:12 PM
RE: Smoking engine - by Bob Culver - 26-08-2018, 11:08 PM
RE: Smoking engine - by Ruairidh Dunford - 27-08-2018, 08:11 AM
RE: Smoking engine - by Colin Reed - 27-08-2018, 09:35 AM
RE: Smoking engine - by Ian Williams - 27-08-2018, 08:17 PM
RE: Smoking engine - by Adrian Payne - 27-08-2018, 07:44 PM
RE: Smoking engine - by Ruairidh Dunford - 27-08-2018, 07:52 PM
RE: Smoking engine - by Pete H - 01-09-2018, 10:17 AM
RE: Smoking engine - by Adrian Payne - 09-09-2018, 08:43 PM
RE: Smoking engine - by Ruairidh Dunford - 09-09-2018, 09:24 PM
RE: Smoking engine - by Bob Culver - 10-09-2018, 07:22 AM
RE: Smoking engine - by Ian McGowan - 10-09-2018, 11:15 AM
RE: Smoking engine - by Adrian Payne - 10-09-2018, 12:44 PM
RE: Smoking engine - by Ian McGowan - 10-09-2018, 01:18 PM
