Hydraulic brake conversion backplate
#26
Terrytuned
Thanks for that (I was typing my above when you posted)
Just wonder if the springs are needed at all or just bolts set to correct length.
How did you decide where to drill the hole in the back plate?   presumably you have this system fitted and working and the shoes will travel from fully in when new to their fully out when worn position without fowling the bolt.
Dennis
Hydraulic brake conversion backplate - by Mgibson - 05-02-2018, 09:17 PM
RE: Hydraulic brake conversion backplate - by Dennis Nicholas - 26-08-2018, 10:11 PM
