engine won't rev
#44
(21-08-2018, 09:43 PM)hibbo Wrote:
(21-08-2018, 09:23 PM)Reckless Rat Wrote: Graham, setting the timing on a Seven is an ongoing thing if youve got a manual advance dizzy. Set it to 1 1/4" BTDC on the flywheel and then take the car out on the road and play about with the adv/retard on the move. If you back the timing off so theres no rumble whatsoever then you'll get nowhere. You've got to do it by feel not ear. Ideally you need an experienced sevener to help you out.
Thanks for the info, I will take your advice.
(21-08-2018, 09:11 PM)Andy Bennett Wrote: Ah, so now making a bit more sense. You aren't getting 30mph in second, it is actually 15 and showing a more expected percentage increase in speed per gear. But yes you should be able to get 40 plus (I get 45, but many get 50) especially given the compression etc and apparent engine condition you mentioned earlier.
I don't think you have mentioned the jet sizes you have?
It might be that you aren't actually far away and just need some final set up help with timing etc. checking coil integrity etc. Have you tried swapping out the coil?
Have you joined your local A7 club as a session with a seasoned owner might give you the tweaks needed to get that extra mph.
Plugs are NGK A6, Champion B16
Andy B
My local A7 club is not that local at 27mph I will swap the coil I have a 6v motorcycle coil, and check the jet sizes, should have done it today when a had the carb in bits again.
To be honest it did feel a little better tonight despite the popping/spitting  from the carb.
Hi again, I seem to have got it running a bit better today but haven't tried it on the road yet.
The jets I have are main .57 comp .50 and slow .60 I think they are right but the weaker end of the options.
Regards
Graham
engine won't rev - by hibbo - 20-08-2018, 02:59 PM
RE: engine won't rev - by Andy Bennett - 20-08-2018, 04:14 PM
RE: engine won't rev - by hibbo - 20-08-2018, 05:22 PM
RE: engine won't rev - by Chris KC - 20-08-2018, 04:22 PM
RE: engine won't rev - by Austin in the Shed - 20-08-2018, 04:43 PM
RE: engine won't rev - by dickie65 - 20-08-2018, 04:58 PM
RE: engine won't rev - by Reckless Rat - 20-08-2018, 04:59 PM
RE: engine won't rev - by Pricey - 20-08-2018, 05:21 PM
RE: engine won't rev - by John Mason - 20-08-2018, 05:22 PM
RE: engine won't rev - by Jeff Taylor - 20-08-2018, 05:53 PM
RE: engine won't rev - by hibbo - 20-08-2018, 06:17 PM
RE: engine won't rev - by Ruairidh Dunford - 20-08-2018, 06:26 PM
RE: engine won't rev - by hibbo - 20-08-2018, 07:21 PM
RE: engine won't rev - by Reckless Rat - 20-08-2018, 07:26 PM
RE: engine won't rev - by John Cornforth - 20-08-2018, 08:24 PM
RE: engine won't rev - by hibbo - 21-08-2018, 09:59 AM
RE: engine won't rev - by Ken Morton - 20-08-2018, 08:32 PM
RE: engine won't rev - by Hedd Jones - 20-08-2018, 08:46 PM
RE: engine won't rev - by Bob Culver - 20-08-2018, 08:46 PM
RE: engine won't rev - by Reckless Rat - 20-08-2018, 08:55 PM
RE: engine won't rev - by Eddamoo - 20-08-2018, 09:08 PM
RE: engine won't rev - by Jeff Taylor - 20-08-2018, 11:42 PM
RE: engine won't rev - by Andy Bennett - 21-08-2018, 11:31 AM
RE: engine won't rev - by Chris KC - 21-08-2018, 11:40 AM
RE: engine won't rev - by Reckless Rat - 21-08-2018, 11:55 AM
RE: engine won't rev - by hibbo - 21-08-2018, 12:11 PM
RE: engine won't rev - by Andy Bennett - 21-08-2018, 04:29 PM
RE: engine won't rev - by Reckless Rat - 21-08-2018, 04:36 PM
RE: engine won't rev - by hibbo - 21-08-2018, 05:45 PM
RE: engine won't rev - by Colin Wilks - 21-08-2018, 05:09 PM
RE: engine won't rev - by Scarlet O'Hara - 21-08-2018, 05:42 PM
RE: engine won't rev - by Paul N-M - 21-08-2018, 06:03 PM
RE: engine won't rev - by hibbo - 21-08-2018, 06:38 PM
RE: engine won't rev - by hibbo - 21-08-2018, 08:44 PM
RE: engine won't rev - by Ruairidh Dunford - 21-08-2018, 06:22 PM
RE: engine won't rev - by Reckless Rat - 21-08-2018, 07:36 PM
RE: engine won't rev - by Andy Bennett - 21-08-2018, 09:11 PM
RE: engine won't rev - by Reckless Rat - 21-08-2018, 09:23 PM
RE: engine won't rev - by hibbo - 21-08-2018, 09:43 PM
RE: engine won't rev - by hibbo - 22-08-2018, 07:29 PM
RE: engine won't rev - by Alan - 21-08-2018, 09:59 PM
RE: engine won't rev - by Hedd Jones - 21-08-2018, 11:06 PM
RE: engine won't rev - by Bob Culver - 21-08-2018, 11:45 PM
RE: engine won't rev - by John Mason - 22-08-2018, 08:44 AM
RE: engine won't rev - by Charles P - 22-08-2018, 07:40 PM
RE: engine won't rev - by Ruairidh Dunford - 22-08-2018, 07:45 PM
RE: engine won't rev - by hibbo - 25-08-2018, 07:25 PM
RE: engine won't rev - by Ruairidh Dunford - 25-08-2018, 07:34 PM
RE: engine won't rev - by hibbo - 25-08-2018, 08:15 PM
RE: engine won't rev - by Reckless Rat - 25-08-2018, 08:42 PM
RE: engine won't rev - by hibbo - 25-08-2018, 09:08 PM
RE: engine won't rev - by Reckless Rat - 25-08-2018, 09:16 PM
RE: engine won't rev - by hibbo - 25-08-2018, 09:50 PM
RE: engine won't rev - by Reckless Rat - 26-08-2018, 08:29 AM
RE: engine won't rev - by "Slack Alice" Simon - 26-08-2018, 12:09 PM
RE: engine won't rev - by hibbo - 26-08-2018, 03:31 PM
RE: engine won't rev - by Andy Bennett - 26-08-2018, 04:02 PM
