21-08-2018, 09:23 PM
(This post was last modified: 21-08-2018, 09:26 PM by Reckless Rat.)
Graham, setting the timing on a Seven is an ongoing thing if youve got a manual advance dizzy. Set it to 1 1/4" BTDC on the flywheel and then take the car out on the road and play about with the adv/retard on the move. If you back the timing off so theres no rumble whatsoever then you'll get nowhere. You've got to do it by feel not ear. Ideally you need an experienced sevener to help you out.
