21-08-2018, 05:45 PM
(21-08-2018, 04:36 PM)Reckless Rat Wrote: Graham could you indicate to us which distributor is fitted to your car, and whether or not the manual advance/retard connection is operating, or is locked off. Whilst you say you've checked the timing can you tell us what you've set it to, and how.
Hi, it's a Lucas distributor with manual advance retard which is working as it should, originally timed it tdc full advance, and then I tried doing it by ear which has worked for me on many other engine's. I have today stripped the carb again, it's now spotless and all the jets have been checked and are clear, also stripped the fuel pump and filters put more fresh fuel in.
Also tried with the cap of in case of a vacuum lock.
Regards
Graham
Ps the plugs appear to me to be indicating a rich mixture !
