engine won't rev
#27
Hi Graham
Sorry to labour the point, but if you are getting 30mph in second gear then whether or not you are jiggling with the choke, and so perhaps have a mixture issue, revving is certainly not a fundamental problem, as you must be revving its nuts off to get to 30mph in second, unless you aren't.
I wonder what speed you would get to in second if you didn't jiggle the choke. It might be that jiggling the choke is a false indicator, as you might be using to exceed reasonable performance expectations.
Can you do a baseline test, no choke jiggling, what speed to you get to in each gear, at reasonable revs, both on gauge and on sat nav. Then you have a baseline which others may be able to help you from, as right now I am not sure that it is really clear what the car is actually achieving.
I also wonder about your brake comment, there should be no friction at all when not operating the brakes. Wheels should spin freely, not just rotate by hand. I set mine so that when you manually tug on the cable you get about 5mm of movement before the shoe bites, effectively slack in the cable. This gives some free movement in the system before anything binds up.
Andy
engine won't rev - by hibbo - 20-08-2018, 02:59 PM
RE: engine won't rev - by Andy Bennett - 20-08-2018, 04:14 PM
RE: engine won't rev - by hibbo - 20-08-2018, 05:22 PM
RE: engine won't rev - by Chris KC - 20-08-2018, 04:22 PM
RE: engine won't rev - by Austin in the Shed - 20-08-2018, 04:43 PM
RE: engine won't rev - by dickie65 - 20-08-2018, 04:58 PM
RE: engine won't rev - by Reckless Rat - 20-08-2018, 04:59 PM
RE: engine won't rev - by Pricey - 20-08-2018, 05:21 PM
RE: engine won't rev - by John Mason - 20-08-2018, 05:22 PM
RE: engine won't rev - by Jeff Taylor - 20-08-2018, 05:53 PM
RE: engine won't rev - by hibbo - 20-08-2018, 06:17 PM
RE: engine won't rev - by Ruairidh Dunford - 20-08-2018, 06:26 PM
RE: engine won't rev - by hibbo - 20-08-2018, 07:21 PM
RE: engine won't rev - by Reckless Rat - 20-08-2018, 07:26 PM
RE: engine won't rev - by John Cornforth - 20-08-2018, 08:24 PM
RE: engine won't rev - by hibbo - 21-08-2018, 09:59 AM
RE: engine won't rev - by Ken Morton - 20-08-2018, 08:32 PM
RE: engine won't rev - by Hedd Jones - 20-08-2018, 08:46 PM
RE: engine won't rev - by Bob Culver - 20-08-2018, 08:46 PM
RE: engine won't rev - by Reckless Rat - 20-08-2018, 08:55 PM
RE: engine won't rev - by Eddamoo - 20-08-2018, 09:08 PM
RE: engine won't rev - by Jeff Taylor - 20-08-2018, 11:42 PM
RE: engine won't rev - by Andy Bennett - 21-08-2018, 11:31 AM
RE: engine won't rev - by Chris KC - 21-08-2018, 11:40 AM
RE: engine won't rev - by Reckless Rat - 21-08-2018, 11:55 AM
RE: engine won't rev - by hibbo - 21-08-2018, 12:11 PM
RE: engine won't rev - by Andy Bennett - 21-08-2018, 04:29 PM
RE: engine won't rev - by Reckless Rat - 21-08-2018, 04:36 PM
RE: engine won't rev - by hibbo - 21-08-2018, 05:45 PM
RE: engine won't rev - by Colin Wilks - 21-08-2018, 05:09 PM
RE: engine won't rev - by Scarlet O'Hara - 21-08-2018, 05:42 PM
RE: engine won't rev - by Paul N-M - 21-08-2018, 06:03 PM
RE: engine won't rev - by hibbo - 21-08-2018, 06:38 PM
RE: engine won't rev - by hibbo - 21-08-2018, 08:44 PM
RE: engine won't rev - by Ruairidh Dunford - 21-08-2018, 06:22 PM
RE: engine won't rev - by Reckless Rat - 21-08-2018, 07:36 PM
RE: engine won't rev - by Andy Bennett - 21-08-2018, 09:11 PM
RE: engine won't rev - by Reckless Rat - 21-08-2018, 09:23 PM
RE: engine won't rev - by hibbo - 21-08-2018, 09:43 PM
RE: engine won't rev - by hibbo - 22-08-2018, 07:29 PM
RE: engine won't rev - by Alan - 21-08-2018, 09:59 PM
RE: engine won't rev - by Hedd Jones - 21-08-2018, 11:06 PM
RE: engine won't rev - by Bob Culver - 21-08-2018, 11:45 PM
RE: engine won't rev - by John Mason - 22-08-2018, 08:44 AM
RE: engine won't rev - by Charles P - 22-08-2018, 07:40 PM
RE: engine won't rev - by Ruairidh Dunford - 22-08-2018, 07:45 PM
RE: engine won't rev - by hibbo - 25-08-2018, 07:25 PM
RE: engine won't rev - by Ruairidh Dunford - 25-08-2018, 07:34 PM
RE: engine won't rev - by hibbo - 25-08-2018, 08:15 PM
RE: engine won't rev - by Reckless Rat - 25-08-2018, 08:42 PM
RE: engine won't rev - by hibbo - 25-08-2018, 09:08 PM
RE: engine won't rev - by Reckless Rat - 25-08-2018, 09:16 PM
RE: engine won't rev - by hibbo - 25-08-2018, 09:50 PM
RE: engine won't rev - by Reckless Rat - 26-08-2018, 08:29 AM
RE: engine won't rev - by "Slack Alice" Simon - 26-08-2018, 12:09 PM
RE: engine won't rev - by hibbo - 26-08-2018, 03:31 PM
RE: engine won't rev - by Andy Bennett - 26-08-2018, 04:02 PM
