20-08-2018, 09:08 PM
Sounds like a definite restriction in fuel supply. As you've already cleaned the carb many times, i would do As John Cornforth said and make sure there is no restriction in the fuel pipe gauze.
Modern fuel gels terribly and we found that after just a few months, the top of the fuel pump (with the 1-way valves) was completely blocked with crud. Give that a go
