Hub seals and brake linings
I noticed that my back brakes were getting progressively more feeble and this is what I found:
On one side the linings had fallen completely to pieces and on the other side they were completely soaked in axle oil which had the positive effect of reducing the level of disintegration, but didn't do much for the braking.
Last year I relined the brakes and removed the hubs, filed off the high spots and replaced them with loctite flange seaer but no paper gaskets. Since then I have done Wiscombe twice, Prescott and about 500 road miles.
I see that there has been some discussion about keeping the oil/grease out of the brakes. The oil appears to be getting through the flange and not through the felt seal.  I plan to fit sealed wheel bearings, reinstate the flange gaskets with a smear of hermatite or similar and drill some holes in the bottom of the axle tubes. What is the  view of this approach?
Regarding the brake linings, these were the soft grey type and they appear to have split across the rivet heads. Possibly I clamped the rivets up too tight when I was fitting them and damaged the linings? I have another set which are made of a brown fibre with metal reinforcement and I suspect they may be a bit tougher? Has anyone come across this problem before? Is it worth getting bonded linings?
Hub seals and brake linings - by Tom Coates - 14-08-2018, 10:12 AM
RE: Hub seals and brake linings - by Steve Jones - 14-08-2018, 10:47 AM
RE: Hub seals and brake linings - by Tom Coates - 14-08-2018, 01:46 PM
RE: Hub seals and brake linings - by Jeff Taylor - 14-08-2018, 04:53 PM
RE: Hub seals and brake linings - by Matt_Harnden - 14-08-2018, 11:37 AM
RE: Hub seals and brake linings - by Steve Jones - 14-08-2018, 02:16 PM
RE: Hub seals and brake linings - by Tom Coates - 14-08-2018, 03:24 PM
RE: Hub seals and brake linings - by Steve Jones - 14-08-2018, 05:45 PM
