Clutch Levers Position - Clutch not releasing
The problem is usually caused by wear in the slots where the levers bear.
Fitting grub screws as suggested by Charles solves the problem at the cause and also makes the levers adjustable.
RE: Clutch Levers Position - Clutch not releasing - by AustinWood - 11-08-2018, 08:21 AM
