Clutch Levers Position - Clutch not releasing
(10-08-2018, 07:21 PM)Eddamoo Wrote: Thanks for all the excellent advice all (as usual!), those lever rollers look great!
The only thing i'm confused about is where you say you "Set" the levers?  The only way i can remember you can move the levers is to loosen the clutch itself (and shim it with washers).  Is there another way please?
you have to bend the levers to set them. When I did mine I used the induction device to heat them first.
Bryan
RE: Clutch Levers Position - Clutch not releasing - by Bryan - 10-08-2018, 10:02 PM
