10-08-2018, 12:05 AM
The levers are to low, I set them 1 1/4" to 1 5/16" above the steel face of the clutch plate to the top of the lever bearing face. I find using rollers under the levers
against the the pillars the best method usually a 5mm roller is enough (see photo) the max size would be 5.5mm, this also gives a much better clutch action.
Terry.
Terry.
