Would like Camshaft Specs
Hi Robert, thanks for reply, the reason for the cam is all three bearings will be plain. and  gears  straight cut,
will also have no dynamo or distributor and be running a Scintilla mag with drive from a skew gear on the crank.
There are a lot of other mods as will be running between 12 & 15 PSI Boost
Colin
Tinopai NZ
Would like Camshaft Specs - by Colin Reed - 06-08-2018, 09:59 PM
RE: Would like Camshaft Specs - by DavidK - 06-08-2018, 11:08 PM
RE: Would like Camshaft Specs - by Colin Reed - 07-08-2018, 04:02 AM
RE: Would like Camshaft Specs - by Ian Williams - 07-08-2018, 05:05 AM
RE: Would like Camshaft Specs - by Colin Reed - 07-08-2018, 10:15 AM
RE: Would like Camshaft Specs - by Robert Foreman - 07-08-2018, 07:03 PM
RE: Would like Camshaft Specs - by Colin Reed - 07-08-2018, 09:23 PM
RE: Would like Camshaft Specs - by Charles P - 08-08-2018, 10:01 PM
RE: Would like Camshaft Specs - by Colin Reed - 09-08-2018, 04:48 AM
RE: Would like Camshaft Specs - by Chris KC - 09-08-2018, 08:10 AM
RE: Would like Camshaft Specs - by Ian Williams - 09-08-2018, 07:21 AM
RE: Would like Camshaft Specs - by Colin Reed - 09-08-2018, 09:26 AM
RE: Would like Camshaft Specs - by Charles P - 09-08-2018, 12:32 PM
RE: Would like Camshaft Specs - by Robert Foreman - 09-08-2018, 05:25 PM
RE: Would like Camshaft Specs - by Ian Williams - 09-08-2018, 09:22 PM
RE: Would like Camshaft Specs - by Colin Reed - 09-08-2018, 09:42 PM
RE: Would like Camshaft Specs - by Speedex750 - 10-08-2018, 03:07 PM
