03-08-2018, 09:31 PM
I used formers made from MDF and various clamps and a vice making mine.
![[Image: main.php?g2_view=core.DownloadItem&g2_it...alNumber=1]](http://asciimation.co.nz/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=1920&g2_serialNumber=1)
And this was the block of wood I used.
![[Image: main.php?g2_view=core.DownloadItem&g2_it...alNumber=1]](http://asciimation.co.nz/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=1986&g2_serialNumber=1)
End result was this. The sheet steel down the side was all done by hand. The flared holes were hand hammered over a block of wood with a hole drilled through it that I had used a router on the edge to give me the curve. You can buy punch and flare tools of course but that worked fine and is cheap!
![[Image: main.php?g2_view=core.DownloadItem&g2_it...alNumber=1]](http://asciimation.co.nz/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=4231&g2_serialNumber=1)
This was my first go so I think this is a viable method for a beginner. Took some trial and error but steel tube is cheap. Mess a piece up and it's easy to chop it out, grind it back and try again. I also probably have too much tube there. I did remove some bits before skinning. After skinning it we saw that a lot of the tubing wasn't really needed. A wired aluminium edge is pretty strong and rigid by itself. I didn't really need a tube all the around the cockpit opening.
My next car (not an Austin) needs timber framing. Have no idea where I can source suitable ash here in NZ yet.
Simon
Simon
