26-07-2018, 06:09 PM
(This post was last modified: 26-07-2018, 06:10 PM by AustinWood.)
I have a rogue half shaft that is only rough finished where the seal near to diff fits so it always leaks.
To prevent oil getting onto the brakes I've fitted seal wheel bearing in the hub. I have also fitted a lip seal in the hub. By making sure the two halves of the hub are sealed together oil cannot get out of the hub onto the brakes.
This has fixed the problem.
