  • 1 Vote(s) - 5 Average
Engine assembly questions.
Used timing gears do not wear uniformly.
The front of the crank in particular deflects here and there when running. One local had a timing gear break from its hub due insufficent clearance.
Some other makes had an extra cam and spring loaded follower to counter the reverse effect.
Many others used fibre gears and from Model As to Holdens all failed eventually.
Engine assembly questions. - by jansens - 24-07-2018, 07:56 AM
RE: Engine assembly questions. - by jansens - 24-07-2018, 09:03 PM
RE: Engine assembly questions. - by jansens - 25-07-2018, 09:25 AM
RE: Engine assembly questions. - by AustinWood - 25-07-2018, 12:06 PM
RE: Engine assembly questions. - by Chris Garner - 25-07-2018, 12:32 PM
RE: Engine assembly questions. - by jansens - 25-07-2018, 06:43 PM
RE: Engine assembly questions. - by Peter Lawson - 25-07-2018, 11:14 PM
RE: Engine assembly questions. - by Ian Williams - 25-07-2018, 10:40 PM
RE: Engine assembly questions. - by jansens - 26-07-2018, 04:08 AM
RE: Engine assembly questions. - by Bob Culver - 26-07-2018, 05:09 AM
RE: Engine assembly questions. - by jansens - 26-07-2018, 06:05 AM
RE: Engine assembly questions. - by Ian Williams - 26-07-2018, 06:06 AM
RE: Engine assembly questions. - by jansens - 26-07-2018, 06:50 AM
RE: Engine assembly questions. - by Ian Williams - 26-07-2018, 09:57 PM
RE: Engine assembly questions. - by jansens - 27-07-2018, 04:16 AM
RE: Engine assembly questions. - by Bob Culver - 27-07-2018, 08:10 AM
RE: Engine assembly questions. - by jansens - 01-08-2018, 08:11 AM
