fitting luggage rack to 7 RP box
Peter,
These are the two chassis extensions Hedd is referring to - these extensions are an integral part of all RP high frame chassis like yours - note the two body floorpan attachment bolt holes on either extension. As you can see the extensions are rather narrow and actually end forward of the rear axle, they don't extend beyond it. Have a look underneath the back of your car and you should be able to see them and decide how best to make up angle iron brackets similar those Hedd's late father made that will match up with the brackets on your luggage rack.
.png   Screen Shot 2018-07-24 at 23.46.54.png (Size: 782.87 KB / Downloads: 343)
fitting luggage rack to 7 RP box - by plawrie - 23-07-2018, 08:50 PM
RE: fitting luggage rack to 7 RP box - by plawrie - 23-07-2018, 09:52 PM
RE: fitting luggage rack to 7 RP box - by plawrie - 24-07-2018, 11:29 AM
RE: fitting luggage rack to 7 RP box - by plawrie - 24-07-2018, 06:25 PM
RE: fitting luggage rack to 7 RP box - by plawrie - 24-07-2018, 09:48 PM
RE: fitting luggage rack to 7 RP box - by squeak - 24-07-2018, 10:56 PM
RE: fitting luggage rack to 7 RP box - by Jeff Taylor - 25-07-2018, 12:22 AM
RE: fitting luggage rack to 7 RP box - by plawrie - 25-07-2018, 07:39 PM
RE: fitting luggage rack to 7 RP box - by JohnD - 26-07-2018, 01:40 PM
RE: fitting luggage rack to 7 RP box - by plawrie - 26-07-2018, 02:23 PM
