  • 2 Vote(s) - 5 Average
RP Restoration - New Member
#28
Hi Geoff,
Great project you've got there and hats off to taking the hard route of keeping it as an RP!
2nd the heat cycles. Soldering torch from a diy place will do, soak in diesel for a while, heat, tap (2nd the shaped wooded block) and repeat. Hard to explain how hard to hit, it will free up eventually, hopefully the pistons will get another chance to work again.
Tom
RP Restoration - New Member - by Geoff101 - 17-07-2018, 02:10 PM
RE: RP Restoration - New Member - by JonE - 17-07-2018, 02:35 PM
RE: RP Restoration - New Member - by Martin Prior - 17-07-2018, 02:51 PM
RE: RP Restoration - New Member - by Austin Carr - 17-07-2018, 04:39 PM
RE: RP Restoration - New Member - by AustinWood - 17-07-2018, 07:10 PM
RE: RP Restoration - New Member - by Tony Betts - 17-07-2018, 06:02 PM
RE: RP Restoration - New Member - by Reckless Rat - 17-07-2018, 06:40 PM
RE: RP Restoration - New Member - by Tony Betts - 17-07-2018, 07:13 PM
RE: RP Restoration - New Member - by Geoff101 - 17-07-2018, 07:26 PM
RE: RP Restoration - New Member - by Geoff101 - 17-07-2018, 08:30 PM
RE: RP Restoration - New Member - by Tony Betts - 17-07-2018, 08:59 PM
RE: RP Restoration - New Member - by Geoff101 - 17-07-2018, 10:44 PM
RE: RP Restoration - New Member - by squeak - 18-07-2018, 12:40 AM
RE: RP Restoration - New Member - by jansens - 18-07-2018, 03:34 AM
RE: RP Restoration - New Member - by David.H - 18-07-2018, 09:08 AM
RE: RP Restoration - New Member - by Geoff101 - 18-07-2018, 12:38 PM
RE: RP Restoration - New Member - by Jeff Taylor - 18-07-2018, 07:12 PM
RE: RP Restoration - New Member - by Geoff101 - 18-07-2018, 08:15 PM
RE: RP Restoration - New Member - by Geoff101 - 22-07-2018, 09:34 PM
RE: RP Restoration - New Member - by Bob Culver - 23-07-2018, 09:00 AM
RE: RP Restoration - New Member - by Geoff101 - 23-07-2018, 10:19 AM
RE: RP Restoration - New Member - by Jeff Taylor - 23-07-2018, 12:34 PM
RE: RP Restoration - New Member - by Hedd_Jones - 23-07-2018, 03:10 PM
RE: RP Restoration - New Member - by Ray White - 23-07-2018, 03:46 PM
RE: RP Restoration - New Member - by Geoff101 - 23-07-2018, 04:36 PM
RE: RP Restoration - New Member - by AustinWood - 23-07-2018, 06:40 PM
RE: RP Restoration - New Member - by Tom the Blacksmith - 24-07-2018, 01:18 AM
RE: RP Restoration - New Member - by Geoff101 - 27-07-2018, 03:23 PM
RE: RP Restoration - New Member - by Ray White - 27-07-2018, 06:40 PM
RE: RP Restoration - New Member - by Hedd Jones - 27-07-2018, 11:13 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 09:56 AM
RE: RP Restoration - New Member - by Hedd_Jones - 01-08-2018, 03:00 PM
RE: RP Restoration - New Member - by fatcatvera - 01-08-2018, 03:00 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 03:06 PM
RE: RP Restoration - New Member - by EB65 VN - 01-08-2018, 03:25 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 03:34 PM
RE: RP Restoration - New Member - by daveg - 01-08-2018, 03:57 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 04:01 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 05:50 PM
RE: RP Restoration - New Member - by Martin Prior - 01-08-2018, 05:57 PM
RE: RP Restoration - New Member - by Ray White - 01-08-2018, 07:53 PM
RE: RP Restoration - New Member - by Ian Williams - 01-08-2018, 08:13 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 09:15 PM
RE: RP Restoration - New Member - by Tony Saward - 02-08-2018, 10:53 AM
