  • 2 Vote(s) - 5 Average
RP Restoration - New Member
#21
Chevrolets were about the only car to retain iron pistons post 1930.
Cycles of heat on the stuck piston may help to free. If you have nothing else can be held over a candle! Clean bore with very fine paper. The conrod and white metal are precious so do not damage. The rings are sure to be stuck after piston is pursuaded out. Standing a household iron on the crown can be used to heat and may free. If wear is moderate and piston skirts not collapsed, pistons and bores may be reusable.
The crankpins are drilled to provide communication from the oil receiving troughs in webs to the crankpins. If you have not noticed  the oil jets in crankcase, take care not to damage.
RP Restoration - New Member - by Geoff101 - 17-07-2018, 02:10 PM
RE: RP Restoration - New Member - by JonE - 17-07-2018, 02:35 PM
RE: RP Restoration - New Member - by Martin Prior - 17-07-2018, 02:51 PM
RE: RP Restoration - New Member - by Austin Carr - 17-07-2018, 04:39 PM
RE: RP Restoration - New Member - by AustinWood - 17-07-2018, 07:10 PM
RE: RP Restoration - New Member - by Tony Betts - 17-07-2018, 06:02 PM
RE: RP Restoration - New Member - by Reckless Rat - 17-07-2018, 06:40 PM
RE: RP Restoration - New Member - by Tony Betts - 17-07-2018, 07:13 PM
RE: RP Restoration - New Member - by Geoff101 - 17-07-2018, 07:26 PM
RE: RP Restoration - New Member - by Geoff101 - 17-07-2018, 08:30 PM
RE: RP Restoration - New Member - by Tony Betts - 17-07-2018, 08:59 PM
RE: RP Restoration - New Member - by Geoff101 - 17-07-2018, 10:44 PM
RE: RP Restoration - New Member - by squeak - 18-07-2018, 12:40 AM
RE: RP Restoration - New Member - by jansens - 18-07-2018, 03:34 AM
RE: RP Restoration - New Member - by David.H - 18-07-2018, 09:08 AM
RE: RP Restoration - New Member - by Geoff101 - 18-07-2018, 12:38 PM
RE: RP Restoration - New Member - by Jeff Taylor - 18-07-2018, 07:12 PM
RE: RP Restoration - New Member - by Geoff101 - 18-07-2018, 08:15 PM
RE: RP Restoration - New Member - by Geoff101 - 22-07-2018, 09:34 PM
RE: RP Restoration - New Member - by Bob Culver - 23-07-2018, 09:00 AM
RE: RP Restoration - New Member - by Geoff101 - 23-07-2018, 10:19 AM
RE: RP Restoration - New Member - by Jeff Taylor - 23-07-2018, 12:34 PM
RE: RP Restoration - New Member - by Hedd_Jones - 23-07-2018, 03:10 PM
RE: RP Restoration - New Member - by Ray White - 23-07-2018, 03:46 PM
RE: RP Restoration - New Member - by Geoff101 - 23-07-2018, 04:36 PM
RE: RP Restoration - New Member - by AustinWood - 23-07-2018, 06:40 PM
RE: RP Restoration - New Member - by Geoff101 - 27-07-2018, 03:23 PM
RE: RP Restoration - New Member - by Ray White - 27-07-2018, 06:40 PM
RE: RP Restoration - New Member - by Hedd Jones - 27-07-2018, 11:13 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 09:56 AM
RE: RP Restoration - New Member - by Hedd_Jones - 01-08-2018, 03:00 PM
RE: RP Restoration - New Member - by fatcatvera - 01-08-2018, 03:00 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 03:06 PM
RE: RP Restoration - New Member - by EB65 VN - 01-08-2018, 03:25 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 03:34 PM
RE: RP Restoration - New Member - by daveg - 01-08-2018, 03:57 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 04:01 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 05:50 PM
RE: RP Restoration - New Member - by Martin Prior - 01-08-2018, 05:57 PM
RE: RP Restoration - New Member - by Ray White - 01-08-2018, 07:53 PM
RE: RP Restoration - New Member - by Ian Williams - 01-08-2018, 08:13 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 09:15 PM
RE: RP Restoration - New Member - by Tony Saward - 02-08-2018, 10:53 AM
