RN Windscreen rubber
(19-07-2018, 07:18 PM)bystander Wrote: If I am interpreting your first photo correctly, your frame is the later of the steel types, fitted just before the chrome-on-brass screen was introduced. I believe there were 3 different profiles of rubber seal on the various steel framed screens, and the one you want slides in the central groove that you can see looking at the frame edge-on. It does not need to be formed around the corners for a good seal like the later brass frames. Jamie at the Seven Workshop lists it as part number B0402A, and I am sure he will send you a small sample on request. No Austin Seven saloon originally had a seal fixed to the body - always a bodge to get around this notoriously leaky area.
Unfortunately this is where I was getting confused because there is no central groove on the edge. It seems that it is 2 pieces of frame one fits inside the outer and fits the rubber between them.
RN Windscreen rubber - by Biddlecombe - 19-07-2018, 12:52 PM
RE: RN Windscreen rubber - by JonE - 19-07-2018, 01:04 PM
RE: RN Windscreen rubber - by Jeff Taylor - 19-07-2018, 01:08 PM
RE: RN Windscreen rubber - by Biddlecombe - 19-07-2018, 03:22 PM
RE: RN Windscreen rubber - by bob46320 - 19-07-2018, 04:09 PM
RE: RN Windscreen rubber - by Biddlecombe - 19-07-2018, 04:14 PM
RE: RN Windscreen rubber - by Biddlecombe - 19-07-2018, 07:02 PM
RE: RN Windscreen rubber - by Jeff Taylor - 19-07-2018, 07:08 PM
RE: RN Windscreen rubber - by bystander - 19-07-2018, 07:18 PM
RE: RN Windscreen rubber - by Biddlecombe - 19-07-2018, 07:30 PM
RE: RN Windscreen rubber - by bystander - 19-07-2018, 07:46 PM
RE: RN Windscreen rubber - by Dave Mann - 19-07-2018, 07:54 PM
RE: RN Windscreen rubber - by Biddlecombe - 19-07-2018, 08:27 PM
RE: RN Windscreen rubber - by Spex - 19-07-2018, 09:39 PM
RE: RN Windscreen rubber - by Dave Mann - 20-07-2018, 09:13 AM
RE: RN Windscreen rubber - by Biddlecombe - 20-07-2018, 10:19 AM
RE: RN Windscreen rubber - by Dave Mann - 24-07-2018, 08:59 AM
RE: RN Windscreen rubber - by Biddlecombe - 24-07-2018, 11:35 AM
RE: RN Windscreen rubber - by Biddlecombe - 24-07-2018, 05:23 PM
RE: RN Windscreen rubber - by Dave Mann - 25-07-2018, 08:36 AM
RE: RN Windscreen rubber - by Biddlecombe - 25-07-2018, 09:14 AM
RE: RN Windscreen rubber - by Dave Mann - 28-07-2018, 08:53 AM
