  • 2 Vote(s) - 5 Average
RP Restoration - New Member
(18-07-2018, 12:40 AM)squeak Wrote: AS you proceed, photograph, photograph, photograph before you remove bits. Labeled plastic bag including a note inside, items you remove for example body packing pieces.
 BEFORE you remove the body, weld in light diagonal braces internally and in door and roof openings. It can help with later fit of body panels if you drill a 1mm hole through the panel layers before unbolting them, as a guide to replacement position.
Decide where you wish to start and disassemble that only, and leave the rest together until you are ready. Too many directions for your endeavors leads to lost parts, lost enthusiasm and cash exhaustion.  Oh and join a club.   cheers  Russell
Definitely photograph everything you can. But also don't assume what is there now is correct. The original parts books are very handy for telling you what should be there but don't show how they go together.
Simon
RP Restoration - New Member - by Geoff101 - 17-07-2018, 02:10 PM
RE: RP Restoration - New Member - by JonE - 17-07-2018, 02:35 PM
RE: RP Restoration - New Member - by Martin Prior - 17-07-2018, 02:51 PM
RE: RP Restoration - New Member - by Austin Carr - 17-07-2018, 04:39 PM
RE: RP Restoration - New Member - by AustinWood - 17-07-2018, 07:10 PM
RE: RP Restoration - New Member - by Tony Betts - 17-07-2018, 06:02 PM
RE: RP Restoration - New Member - by Reckless Rat - 17-07-2018, 06:40 PM
RE: RP Restoration - New Member - by Tony Betts - 17-07-2018, 07:13 PM
RE: RP Restoration - New Member - by Geoff101 - 17-07-2018, 07:26 PM
RE: RP Restoration - New Member - by Geoff101 - 17-07-2018, 08:30 PM
RE: RP Restoration - New Member - by Tony Betts - 17-07-2018, 08:59 PM
RE: RP Restoration - New Member - by Geoff101 - 17-07-2018, 10:44 PM
RE: RP Restoration - New Member - by squeak - 18-07-2018, 12:40 AM
RE: RP Restoration - New Member - by jansens - 18-07-2018, 03:34 AM
RE: RP Restoration - New Member - by David.H - 18-07-2018, 09:08 AM
RE: RP Restoration - New Member - by Geoff101 - 18-07-2018, 12:38 PM
RE: RP Restoration - New Member - by Jeff Taylor - 18-07-2018, 07:12 PM
RE: RP Restoration - New Member - by Geoff101 - 18-07-2018, 08:15 PM
RE: RP Restoration - New Member - by Geoff101 - 22-07-2018, 09:34 PM
RE: RP Restoration - New Member - by Bob Culver - 23-07-2018, 09:00 AM
RE: RP Restoration - New Member - by Geoff101 - 23-07-2018, 10:19 AM
RE: RP Restoration - New Member - by Jeff Taylor - 23-07-2018, 12:34 PM
RE: RP Restoration - New Member - by Hedd_Jones - 23-07-2018, 03:10 PM
RE: RP Restoration - New Member - by Ray White - 23-07-2018, 03:46 PM
RE: RP Restoration - New Member - by Geoff101 - 23-07-2018, 04:36 PM
RE: RP Restoration - New Member - by AustinWood - 23-07-2018, 06:40 PM
RE: RP Restoration - New Member - by Geoff101 - 27-07-2018, 03:23 PM
RE: RP Restoration - New Member - by Ray White - 27-07-2018, 06:40 PM
RE: RP Restoration - New Member - by Hedd Jones - 27-07-2018, 11:13 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 09:56 AM
RE: RP Restoration - New Member - by Hedd_Jones - 01-08-2018, 03:00 PM
RE: RP Restoration - New Member - by fatcatvera - 01-08-2018, 03:00 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 03:06 PM
RE: RP Restoration - New Member - by EB65 VN - 01-08-2018, 03:25 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 03:34 PM
RE: RP Restoration - New Member - by daveg - 01-08-2018, 03:57 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 04:01 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 05:50 PM
RE: RP Restoration - New Member - by Martin Prior - 01-08-2018, 05:57 PM
RE: RP Restoration - New Member - by Ray White - 01-08-2018, 07:53 PM
RE: RP Restoration - New Member - by Ian Williams - 01-08-2018, 08:13 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 09:15 PM
RE: RP Restoration - New Member - by Tony Saward - 02-08-2018, 10:53 AM
