Rear main oil seal
I enlarged the holes in the Phoenix crank in our supercharged single seater special with a series of rotary burrs and a die grinder. After had enlarged the holes, I radiused them to maximize oil flow into the holes in the troughs. I have a small in-line pump that fits onto the end of my battery drill, it has a hose that fits onto the extended oil pick ups and another that goes into a large tin of paraffin.
As Simon notes the jets definitely don't squirt where they point. The flow test is the only way to be sure. As I also fitted the Mike Forrest double oiler conversion, we had to do this for both sets of jets. A large plastic tub under the crank case keeps your boots from filling up with paraffin.... That and the ability to vary the intensity of the flow via the battery drill
Aye
Greig
Rear main oil seal - by jansens - 16-07-2018, 10:14 PM
RE: Rear main oil seal - by Steve Hainsworth - 17-07-2018, 11:45 AM
RE: Rear main oil seal - by Ruairidh Dunford - 17-07-2018, 01:10 PM
RE: Rear main oil seal - by jansens - 17-07-2018, 07:05 PM
RE: Rear main oil seal - by Ruairidh Dunford - 17-07-2018, 07:23 PM
RE: Rear main oil seal - by Greig Smith - 17-07-2018, 07:49 PM
RE: Rear main oil seal - by jansens - 17-07-2018, 08:52 PM
RE: Rear main oil seal - by Ian Williams - 17-07-2018, 10:44 PM
RE: Rear main oil seal - by jansens - 18-07-2018, 12:10 AM
RE: Rear main oil seal - by Ruairidh Dunford - 18-07-2018, 09:35 AM
RE: Rear main oil seal - by jansens - 18-07-2018, 10:44 AM
RE: Rear main oil seal - by Mick Hanna - 18-07-2018, 02:11 PM
RE: Rear main oil seal - by Alan - 18-07-2018, 03:09 PM
RE: Rear main oil seal - by Steve Jones - 18-07-2018, 03:55 PM
RE: Rear main oil seal - by Mick Hanna - 18-07-2018, 08:24 PM
RE: Rear main oil seal - by jansens - 18-07-2018, 11:17 PM
RE: Rear main oil seal - by Mick Hanna - 27-07-2018, 01:45 PM
