  • 2 Vote(s) - 5 Average
RP Restoration - New Member
Thought I'd have another look through your lovely pictures.
And the car body looks in exceptionally good condition.
Before you have it stripped or blasted, I would fit everything back to the car  and make sure it all lines up to were it should be. As the wings look like they were primered at some time. If they are replacements they may need adjusting. Best to do it at this stag on the first fit.
As for money's available, if you can't afford to throw £20k to fully restore it. things like those seats could probably be used as is with a little work. No costs. You could even save on stripping and spraying as it looks good enough to leave the body as an oily rag, very popular now.
With limited finance,
always Work out were your finances need to be put first, otherwise you may never get to use it.
Tony
RP Restoration - New Member - by Geoff101 - 17-07-2018, 02:10 PM
RE: RP Restoration - New Member - by JonE - 17-07-2018, 02:35 PM
RE: RP Restoration - New Member - by Martin Prior - 17-07-2018, 02:51 PM
RE: RP Restoration - New Member - by Austin Carr - 17-07-2018, 04:39 PM
RE: RP Restoration - New Member - by AustinWood - 17-07-2018, 07:10 PM
RE: RP Restoration - New Member - by Tony Betts - 17-07-2018, 06:02 PM
RE: RP Restoration - New Member - by Reckless Rat - 17-07-2018, 06:40 PM
RE: RP Restoration - New Member - by Tony Betts - 17-07-2018, 07:13 PM
RE: RP Restoration - New Member - by Geoff101 - 17-07-2018, 07:26 PM
RE: RP Restoration - New Member - by Geoff101 - 17-07-2018, 08:30 PM
RE: RP Restoration - New Member - by Tony Betts - 17-07-2018, 08:59 PM
RE: RP Restoration - New Member - by Geoff101 - 17-07-2018, 10:44 PM
RE: RP Restoration - New Member - by squeak - 18-07-2018, 12:40 AM
RE: RP Restoration - New Member - by jansens - 18-07-2018, 03:34 AM
RE: RP Restoration - New Member - by David.H - 18-07-2018, 09:08 AM
RE: RP Restoration - New Member - by Geoff101 - 18-07-2018, 12:38 PM
RE: RP Restoration - New Member - by Jeff Taylor - 18-07-2018, 07:12 PM
RE: RP Restoration - New Member - by Geoff101 - 18-07-2018, 08:15 PM
RE: RP Restoration - New Member - by Geoff101 - 22-07-2018, 09:34 PM
RE: RP Restoration - New Member - by Bob Culver - 23-07-2018, 09:00 AM
RE: RP Restoration - New Member - by Geoff101 - 23-07-2018, 10:19 AM
RE: RP Restoration - New Member - by Jeff Taylor - 23-07-2018, 12:34 PM
RE: RP Restoration - New Member - by Hedd_Jones - 23-07-2018, 03:10 PM
RE: RP Restoration - New Member - by Ray White - 23-07-2018, 03:46 PM
RE: RP Restoration - New Member - by Geoff101 - 23-07-2018, 04:36 PM
RE: RP Restoration - New Member - by AustinWood - 23-07-2018, 06:40 PM
RE: RP Restoration - New Member - by Geoff101 - 27-07-2018, 03:23 PM
RE: RP Restoration - New Member - by Ray White - 27-07-2018, 06:40 PM
RE: RP Restoration - New Member - by Hedd Jones - 27-07-2018, 11:13 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 09:56 AM
RE: RP Restoration - New Member - by Hedd_Jones - 01-08-2018, 03:00 PM
RE: RP Restoration - New Member - by fatcatvera - 01-08-2018, 03:00 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 03:06 PM
RE: RP Restoration - New Member - by EB65 VN - 01-08-2018, 03:25 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 03:34 PM
RE: RP Restoration - New Member - by daveg - 01-08-2018, 03:57 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 04:01 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 05:50 PM
RE: RP Restoration - New Member - by Martin Prior - 01-08-2018, 05:57 PM
RE: RP Restoration - New Member - by Ray White - 01-08-2018, 07:53 PM
RE: RP Restoration - New Member - by Ian Williams - 01-08-2018, 08:13 PM
RE: RP Restoration - New Member - by Geoff101 - 01-08-2018, 09:15 PM
RE: RP Restoration - New Member - by Tony Saward - 02-08-2018, 10:53 AM
