11-07-2018, 11:04 PM
The RP combines vintage appearance with useful roominess, 4 speed synchro /constant mesh gears, simple hand advance. Not lively and best suited to slow roads, preferably flat, ideally winding! Brakes may be disturbing but can apparently be made effective.
With sound bes, steering arm, rear axles and hubs, front axle ends, dynamo correctly adjusted, is a very reliable car. Original cranks a liability but if cr not raised and driven reasonably, often very long life. Most cars inevitably need a lot of tinkering but everything is accessible, construction apparent, and components of manageable size and work is not a bewildering and complex chore as with a modern.
Due inherent construction and water leaks past window seals the RP body is very prone to severely rusted doors, rear floor, rear inner guards. Some have escaped and some have been repaired properly. But some are masterpieces of the bog artists skill and, although may look stunning, must be avoided. An owner bravely exposed his disturbing example on this Forum a year or so ago.
