10-07-2018, 05:20 PM
having taken the front suspension & steering links apart & cleaned/renewed etc as necessary I now have to reassemble it all!
Of course I did not take pictures before I took it apart (we NEVER learn....) so I have a few queries!
I cannot find a simple diagram of the layout & my first question is does the side tube (where the drag link ball pin taper goes into the drop arm) go on the outside or inside...Initial push in is ambivalent!. The other end fits on top of the arm I do recall!
I have further confusion because the car had everything pretty loosely put together! No split pins, loose nuts & bits missing!
Is there a simple schematic drawing of the standard steering/suspension layout? The web is full of exotic IFS etc systems!
