Fitting New Ring Gear
The damaged teeth on the cover plate are machined off to a diameter of 9.010" and to the thickness of the new ring gear leaving a flange to locate the new gear.
When the gear has been fitted the half holes that are left must be redrilled using a milling cutter as you are only drilling half a hole in the new ring gear and drilling it with a drill it will not cut true and wander off enlarging the holes.
Terry.
Fitting New Ring Gear - by John P - 03-07-2018, 05:02 PM
RE: Fitting New Ring Gear - by Zetomagneto - 03-07-2018, 05:43 PM
RE: Fitting New Ring Gear - by Stuart Giles - 04-07-2018, 01:26 PM
RE: Fitting New Ring Gear - by Chris KC - 04-07-2018, 02:18 PM
RE: Fitting New Ring Gear - by John P - 04-07-2018, 03:10 PM
RE: Fitting New Ring Gear - by Terrytuned - 04-07-2018, 05:29 PM
RE: Fitting New Ring Gear - by John P - 04-07-2018, 06:18 PM
RE: Fitting New Ring Gear - by John P - 20-07-2018, 11:23 AM
RE: Fitting New Ring Gear - by Ruairidh Dunford - 20-07-2018, 12:19 PM
RE: Fitting New Ring Gear - by GK5268 - 21-07-2018, 09:28 AM
RE: Fitting New Ring Gear - by Robert Leigh - 21-07-2018, 11:47 AM
