RP Rear brake cables
#29
thanks for the feedback Rodger,
 important that the twist is no substitute for any wear in the system including the linings. It is only to achieve 90 degrees where the ball meets the cable when viewed from above.
When viewed from the side, the pendant lever position is controlled by the cutaway for the cotter and, as you have said, the direction in which it is inserted. The cutaway is handed.
 I would not bend the lever to correct any discrepancies here, rather look at whether the cams are on the correct sides and can you adjust the steepness of the cotter.
Whilst on the subject of front cotters , I make my own, about 3 inches long and jutting forward, with a light extension spring between the cotter and backing plate. This to help the brake shoe springs counteract the weight of  front cable and fittings.  cheers  Russell
RP Rear brake cables - by Roger - 27-06-2018, 03:52 PM
RE: RP Rear brake cables - by Chris KC - 27-06-2018, 04:05 PM
RE: RP Rear brake cables - by Roger - 27-06-2018, 04:42 PM
RE: RP Rear brake cables - by Chris KC - 27-06-2018, 04:48 PM
RE: RP Rear brake cables - by Robert Leigh - 28-06-2018, 10:54 AM
RE: RP Rear brake cables - by dickie65 - 27-06-2018, 05:55 PM
RE: RP Rear brake cables - by Roger - 27-06-2018, 09:29 PM
RE: RP Rear brake cables - by Hentzant - 27-06-2018, 06:29 PM
RE: RP Rear brake cables - by Roger - 27-06-2018, 09:17 PM
RE: RP Rear brake cables - by Ian Williams - 27-06-2018, 09:26 PM
RE: RP Rear brake cables - by Roger - 27-06-2018, 11:12 PM
RE: RP Rear brake cables - by Tony Press - 28-06-2018, 03:36 AM
RE: RP Rear brake cables - by Roger - 28-06-2018, 11:33 AM
RE: RP Rear brake cables - by AustinWood - 27-06-2018, 11:44 PM
RE: RP Rear brake cables - by Ian Williams - 28-06-2018, 09:19 PM
RE: RP Rear brake cables - by Roger - 01-07-2018, 06:52 PM
RE: RP Rear brake cables - by Ian Williams - 01-07-2018, 09:04 PM
RE: RP Rear brake cables - by Roger - 01-07-2018, 10:02 PM
RE: RP Rear brake cables - by Ian Williams - 01-07-2018, 11:53 PM
RE: RP Rear brake cables - by Ruairidh Dunford - 02-07-2018, 07:05 AM
RE: RP Rear brake cables - by Roger - 02-07-2018, 02:00 PM
RE: RP Rear brake cables - by Tony Press - 02-07-2018, 11:21 PM
RE: RP Rear brake cables - by Roger - 02-07-2018, 11:37 PM
RE: RP Rear brake cables - by Tony Press - 02-07-2018, 11:56 PM
RE: RP Rear brake cables - by Roger - 03-07-2018, 07:21 PM
RE: RP Rear brake cables - by squeak - 04-07-2018, 01:11 AM
RE: RP Rear brake cables - by AustinWood - 04-07-2018, 06:17 AM
RE: RP Rear brake cables - by Roger - 04-07-2018, 09:48 AM
RE: RP Rear brake cables - by squeak - 04-07-2018, 12:48 PM
RE: RP Rear brake cables - by Tony Press - 05-07-2018, 12:15 AM
RE: RP Rear brake cables - by Roger - 04-07-2018, 01:07 PM
RE: RP Rear brake cables - by Ruairidh Dunford - 05-07-2018, 07:16 AM
RE: RP Rear brake cables - by dickie65 - 06-07-2018, 09:07 PM
RE: RP Rear brake cables - by squeak - 07-07-2018, 01:19 AM
RE: RP Rear brake cables - by Bob Culver - 07-07-2018, 04:44 AM
RE: RP Rear brake cables - by Tony Press - 07-07-2018, 06:04 AM
RE: RP Rear brake cables - by Roger - 07-07-2018, 09:09 AM
RE: RP Rear brake cables - by Roger - 07-07-2018, 10:34 PM
