02-07-2018, 08:33 PM
The recommeded unibond Crystal works really well - really easy to apply. Thanks Stuart.
I've noticed on the A7W units, the pilot/side lights are not quite in line with the black earth wire, which I understand should be at the top to get correct dipping. So should I have the pilot absolutely at the top so the black earth wire is a few degrees from the vertical, or vice versa?
I'm not sure whether the two filaments need to be at a slight angle to give the right 'line' of light. But it eqully might look odd with the pilots a bit skewiff....!
