27-06-2018, 11:12 PM
(27-06-2018, 09:26 PM)Ian Williams Wrote: Reverse the Austin lever so that the ball faces the backplate, or use your homemade lever, I have fitted turnbuckles for adjustment at the cross shaft end of the cable quite successfully.
Thank you Ian, I had not thought of reversing the A7 levers, I thought it would affect the angle of the lever, but the cotter must do that if put in back to front.
Roger
