RP Rear brake cables
(27-06-2018, 04:05 PM)Chris KC Wrote: I'm not sure what problem you foresee Roger - there shouldn't be any significant lateral movement in either springs or cable so they can safely run alongside each other.
Chris,
They are actually in contact where the threaded portion is. (Third leaf up).
Also I would like  some comments on my home made prototype is it an acceptable method to use, it will make adjustments much easier.
Roger
RP Rear brake cables - by Roger - 27-06-2018, 03:52 PM
RE: RP Rear brake cables - by Chris KC - 27-06-2018, 04:05 PM
RE: RP Rear brake cables - by Roger - 27-06-2018, 04:42 PM
RE: RP Rear brake cables - by Chris KC - 27-06-2018, 04:48 PM
RE: RP Rear brake cables - by Robert Leigh - 28-06-2018, 10:54 AM
RE: RP Rear brake cables - by dickie65 - 27-06-2018, 05:55 PM
RE: RP Rear brake cables - by Roger - 27-06-2018, 09:29 PM
RE: RP Rear brake cables - by Hentzant - 27-06-2018, 06:29 PM
RE: RP Rear brake cables - by Roger - 27-06-2018, 09:17 PM
RE: RP Rear brake cables - by Ian Williams - 27-06-2018, 09:26 PM
RE: RP Rear brake cables - by Roger - 27-06-2018, 11:12 PM
RE: RP Rear brake cables - by Tony Press - 28-06-2018, 03:36 AM
RE: RP Rear brake cables - by Roger - 28-06-2018, 11:33 AM
RE: RP Rear brake cables - by AustinWood - 27-06-2018, 11:44 PM
RE: RP Rear brake cables - by Ian Williams - 28-06-2018, 09:19 PM
RE: RP Rear brake cables - by Roger - 01-07-2018, 06:52 PM
RE: RP Rear brake cables - by Ian Williams - 01-07-2018, 09:04 PM
RE: RP Rear brake cables - by Roger - 01-07-2018, 10:02 PM
RE: RP Rear brake cables - by Ian Williams - 01-07-2018, 11:53 PM
RE: RP Rear brake cables - by Ruairidh Dunford - 02-07-2018, 07:05 AM
RE: RP Rear brake cables - by Roger - 02-07-2018, 02:00 PM
RE: RP Rear brake cables - by Tony Press - 02-07-2018, 11:21 PM
RE: RP Rear brake cables - by Roger - 02-07-2018, 11:37 PM
RE: RP Rear brake cables - by Tony Press - 02-07-2018, 11:56 PM
RE: RP Rear brake cables - by Roger - 03-07-2018, 07:21 PM
RE: RP Rear brake cables - by squeak - 04-07-2018, 01:11 AM
RE: RP Rear brake cables - by AustinWood - 04-07-2018, 06:17 AM
RE: RP Rear brake cables - by Roger - 04-07-2018, 09:48 AM
RE: RP Rear brake cables - by squeak - 04-07-2018, 12:48 PM
RE: RP Rear brake cables - by Tony Press - 05-07-2018, 12:15 AM
RE: RP Rear brake cables - by Roger - 04-07-2018, 01:07 PM
RE: RP Rear brake cables - by Ruairidh Dunford - 05-07-2018, 07:16 AM
RE: RP Rear brake cables - by dickie65 - 06-07-2018, 09:07 PM
RE: RP Rear brake cables - by squeak - 07-07-2018, 01:19 AM
RE: RP Rear brake cables - by Bob Culver - 07-07-2018, 04:44 AM
RE: RP Rear brake cables - by Tony Press - 07-07-2018, 06:04 AM
RE: RP Rear brake cables - by Roger - 07-07-2018, 09:09 AM
RE: RP Rear brake cables - by Roger - 07-07-2018, 10:34 PM
