Choice of Rear Axle
(24-06-2018, 03:30 PM)Jamie Wrote:
(05-06-2018, 05:48 PM)Phil Kingdom Wrote: .......... Also choice of wheel size will also make a difference as to how the car performs
Phil,
I have checked and found that they are 17" wheels.
Jamie.
Early Ruby rear axle ratio is 5.25:1 that works out at just under 15 MPH/1000 RPM in top gear with wheel/tyre @ 26" diameter. The OHV Reliant motor is much more free revving than a standard A7 motor, should be OK at a sustained 4000 RPM as long as there's reasonable airflow to the sump or have an an oil cooler installed if not.
Choice of Rear Axle - by Jamie - 05-06-2018, 03:38 PM
RE: Choice of Rear Axle - by Phil Kingdom - 05-06-2018, 05:48 PM
RE: Choice of Rear Axle - by Jamie - 05-06-2018, 09:59 PM
RE: Choice of Rear Axle - by Phil Kingdom - 06-06-2018, 12:08 AM
RE: Choice of Rear Axle - by Stuart Giles - 06-06-2018, 09:04 PM
RE: Choice of Rear Axle - by Jamie - 06-06-2018, 10:12 PM
RE: Choice of Rear Axle - by Phil Kingdom - 07-06-2018, 12:15 AM
RE: Choice of Rear Axle - by Jamie - 24-06-2018, 03:30 PM
RE: Choice of Rear Axle - by AustinWood - 24-06-2018, 05:00 PM
RE: Choice of Rear Axle - by Stuart Giles - 24-06-2018, 10:10 PM
RE: Choice of Rear Axle - by Jamie - 24-06-2018, 10:48 PM
