Voltage at Coil Terminals - Help Please
Nicely put Bob! In any case you need a running engine to use a compression tester properly. If it passes the thumb test it should run.
RE: Voltage at Coil Terminals - Help Please - by Chris KC - 20-06-2018, 10:23 AM
