Gearbox Oil Leaks
Another check to make, if you are intending to remove the first motion shaft, is to check the integrity of the core plug inside the shaft. This prevents oil leaking from inside the box through to the splines. Whilst holding the shaft pour some paraffin or petrol into the inner bearing hole and see if it passes through.
Ron
Gearbox Oil Leaks - by Stumpi - 12-06-2018, 09:33 PM
RE: Gearbox Oil Leaks - by Ian Williams - 12-06-2018, 10:03 PM
RE: Gearbox Oil Leaks - by Stumpi - 12-06-2018, 11:24 PM
RE: Gearbox Oil Leaks - by Terrytuned - 13-06-2018, 01:52 PM
RE: Gearbox Oil Leaks - by Stumpi - 13-06-2018, 09:52 PM
RE: Gearbox Oil Leaks - by Ron Hayhurst - 15-06-2018, 09:27 AM
RE: Gearbox Oil Leaks - by Bob Culver - 15-06-2018, 10:53 AM
RE: Gearbox Oil Leaks - by Ian Williams - 15-06-2018, 09:28 PM
