  • 1 Vote(s) - 2 Average
Rear Axle Half Shaft Changes.
the axle ratio is at the end of the bit you have already cleaned... 9/44.
as R says, date will be above, the three sections quite widely spaced.
David - how long exactly are all your half shafts i.e. are they exactly 23 .5 and 22.5, or are they a bit less, as per my findings in post above?
Rear Axle Half Shaft Changes. - by Tony Press - 22-08-2017, 12:11 AM
RE: Rear Axle Half Shaft Changes. - by Tony Press - 22-08-2017, 01:46 AM
RE: Rear Axle Half Shaft Changes. - by JonE - 12-06-2018, 05:58 PM
RE: Rear Axle Half Shaft Changes. - by Tony Press - 14-06-2018, 10:52 AM
RE: Rear Axle Half Shaft Changes. - by David.H - 13-06-2018, 04:41 PM
RE: Rear Axle Half Shaft Changes. - by Chris KC - 13-06-2018, 04:57 PM
RE: Rear Axle Half Shaft Changes. - by David.H - 13-06-2018, 05:25 PM
RE: Rear Axle Half Shaft Changes. - by JonE - 13-06-2018, 05:48 PM
RE: Rear Axle Half Shaft Changes. - by David.H - 13-06-2018, 10:31 PM
RE: Rear Axle Half Shaft Changes. - by Bob Culver - 14-06-2018, 12:17 AM
RE: Rear Axle Half Shaft Changes. - by Bob Culver - 14-06-2018, 01:48 AM
RE: Rear Axle Half Shaft Changes. - by David.H - 14-06-2018, 11:15 AM
RE: Rear Axle Half Shaft Changes. - by JonE - 14-06-2018, 11:32 AM
RE: Rear Axle Half Shaft Changes. - by Tony Press - 14-06-2018, 12:11 PM
RE: Rear Axle Half Shaft Changes. - by Spex - 14-06-2018, 07:34 PM
RE: Rear Axle Half Shaft Changes. - by David.H - 14-06-2018, 09:37 PM
RE: Rear Axle Half Shaft Changes. - by Bob Culver - 14-06-2018, 11:05 PM
RE: Rear Axle Half Shaft Changes. - by Belinni - 15-03-2022, 01:35 PM
RE: Rear Axle Half Shaft Changes. - by Bob Culver - 16-03-2022, 01:43 AM
