  • 1 Vote(s) - 5 Average
Head bolt leak.
Just to answer Ian's question from a very inexperienced contributor.
My head and block are definitely not flat in that they have not been skimmed in my 9 year ownership and show signs of 'rounding off' around holes. All of which has led to my decision to put together a new top end.
I have had 2 head gaskets go after about 1000 miles (both between 2 and 3). The second one went a few weeks ago, before which I noticed some bubbling around 2 studs, (not around 2-3).
On this second replacement I have taken more care to prepare and check. I added penetrating locktite stud sealer to the bubbling studs (they would nor move with reasonable force and i did not want to risk breakage) in case the water was coming up rather than tracking along the head.
On replacing the gasket I used blue hylomar on both sides. I torgued up, left overnight, torgued again, ran hot and torgued again. I then rechecked torque after 50 or so miles and found that I could tighten by about a quarter of a turn across the head.
Today, after 300 miles I torqued again and strangely 1,2 and 3 all took a further 1/8 turn to 20lb, all others were fine and took no more.
Not sure what that says but to note I do consider this to be a very tired top end and I just hope I have my replacement sorted out before it goes again.
Andy
Head bolt leak. - by Graham Honnor - 10-06-2018, 01:34 PM
RE: Head bolt leak. - by John Mason - 10-06-2018, 03:51 PM
RE: Head bolt leak. - by Graham Honnor - 10-06-2018, 04:22 PM
RE: Head bolt leak. - by Chris KC - 10-06-2018, 04:41 PM
RE: Head bolt leak. - by Graham Honnor - 10-06-2018, 04:57 PM
RE: Head bolt leak. - by Andy Bennett - 10-06-2018, 08:04 PM
RE: Head bolt leak. - by Graham Honnor - 10-06-2018, 08:45 PM
RE: Head bolt leak. - by Nick Turley - 13-06-2018, 10:53 AM
RE: Head bolt leak. - by Michael - 11-06-2018, 08:55 AM
RE: Head bolt leak. - by Terrytuned - 11-06-2018, 10:17 AM
RE: Head bolt leak. - by Steve Jones - 11-06-2018, 10:48 AM
RE: Head bolt leak. - by Charles Levien - 11-06-2018, 06:30 PM
RE: Head bolt leak. - by Graham Honnor - 11-06-2018, 01:35 PM
RE: Head bolt leak. - by dickie65 - 11-06-2018, 05:08 PM
RE: Head bolt leak. - by Ian Williams - 11-06-2018, 09:45 PM
RE: Head bolt leak. - by Michael - 11-06-2018, 11:09 PM
RE: Head bolt leak. - by Graham Honnor - 12-06-2018, 09:30 PM
RE: Head bolt leak. - by Andy Bennett - 12-06-2018, 11:00 PM
RE: Head bolt leak. - by Nick Lettington - 12-06-2018, 11:18 PM
RE: Head bolt leak. - by Speedex750 - 13-06-2018, 04:46 PM
RE: Head bolt leak. - by Graham Honnor - 13-06-2018, 06:25 PM
RE: Head bolt leak. - by Terrytuned - 13-06-2018, 06:58 PM
RE: Head bolt leak. - by Jeff Taylor - 13-06-2018, 07:07 PM
RE: Head bolt leak. - by Colin Morgan - 13-06-2018, 07:35 PM
RE: Head bolt leak. - by Steve Jones - 13-06-2018, 08:01 PM
RE: Head bolt leak. - by Graham Honnor - 13-06-2018, 08:06 PM
RE: Head bolt leak. - by Ian Williams - 13-06-2018, 09:38 PM
RE: Head bolt leak. - by Charles P - 13-06-2018, 09:47 PM
RE: Head bolt leak. - by rubyman - 16-06-2018, 07:41 PM
RE: Head bolt leak. - by Nigel was in Brittany - 16-06-2018, 08:31 PM
RE: Head bolt leak. - by Steve Berg - 28-09-2018, 10:30 AM
RE: Head bolt leak. - by JonE - 28-09-2018, 11:46 AM
RE: Head bolt leak. - by AustinWood - 28-09-2018, 12:00 PM
RE: Head bolt leak. - by Hedd_Jones - 28-09-2018, 01:20 PM
RE: Head bolt leak. - by JonE - 28-09-2018, 02:09 PM
RE: Head bolt leak. - by Hedd_Jones - 28-09-2018, 03:43 PM
RE: Head bolt leak. - by JonE - 28-09-2018, 05:33 PM
RE: Head bolt leak. - by Graham Honnor - 28-09-2018, 04:17 PM
RE: Head bolt leak. - by jansens - 28-09-2018, 08:42 PM
RE: Head bolt leak. - by Graham Honnor - 28-09-2018, 09:21 PM
RE: Head bolt leak. - by Ian Williams - 28-09-2018, 09:26 PM
RE: Head bolt leak. - by Hedd_Jones - 28-09-2018, 09:52 PM
RE: Head bolt leak. - by Colin Reed - 28-09-2018, 10:00 PM
RE: Head bolt leak. - by Chris KC - 29-09-2018, 09:33 AM
RE: Head bolt leak. - by Ian Williams - 29-09-2018, 05:53 AM
RE: Head bolt leak. - by JonE - 29-09-2018, 07:49 AM
RE: Head bolt leak. - by Bob Culver - 29-09-2018, 08:39 AM
RE: Head bolt leak. - by Ian Williams - 29-09-2018, 09:09 AM
RE: Head bolt leak. - by Hedd_Jones - 29-09-2018, 10:43 AM
RE: Head bolt leak. - by carfan - 25-01-2021, 11:32 AM
RE: Head bolt leak. - by Colin Wilks - 25-01-2021, 05:29 PM
RE: Head bolt leak. - by carfan - 25-01-2021, 11:47 PM
RE: Head bolt leak. - by s.earl - 13-06-2022, 10:56 AM
RE: Head bolt leak. - by John Mason - 13-06-2022, 11:41 AM
RE: Head bolt leak. - by Charles Levien - 15-06-2022, 12:52 PM
