  • 1 Vote(s) - 5 Average
Head bolt leak.
Thank you for the reply John.
I would rather not use Barrs except as a last resort as the cooling system has never yet been any problem and the rad has a reasonably new core.
I wondered about putting some plumbers thread sealant on the top part of the stud thread and then replacing the nut but was worried about the continuing presence of water in the head stud column.
Is it likely that the water is seeping across the gasket and then traveling up the stud to the top, in which case I presume it's a head off job again.I did lightly smear the gasket on both sides with copperslip as was advised on here and also used new nuts and washers.
I was however very cautious about not over torquing the nuts and I wondered if it might not do any harm to give the nuts another tweak and see what happens.
I'll await any further responses first and see what the majority advises and then choose my next course of action.
Many thanks again.
Graham.
Head bolt leak. - by Graham Honnor - 10-06-2018, 01:34 PM
RE: Head bolt leak. - by John Mason - 10-06-2018, 03:51 PM
RE: Head bolt leak. - by Graham Honnor - 10-06-2018, 04:22 PM
RE: Head bolt leak. - by Chris KC - 10-06-2018, 04:41 PM
RE: Head bolt leak. - by Graham Honnor - 10-06-2018, 04:57 PM
RE: Head bolt leak. - by Andy Bennett - 10-06-2018, 08:04 PM
RE: Head bolt leak. - by Graham Honnor - 10-06-2018, 08:45 PM
RE: Head bolt leak. - by Nick Turley - 13-06-2018, 10:53 AM
RE: Head bolt leak. - by Michael - 11-06-2018, 08:55 AM
RE: Head bolt leak. - by Terrytuned - 11-06-2018, 10:17 AM
RE: Head bolt leak. - by Steve Jones - 11-06-2018, 10:48 AM
RE: Head bolt leak. - by Charles Levien - 11-06-2018, 06:30 PM
RE: Head bolt leak. - by Graham Honnor - 11-06-2018, 01:35 PM
RE: Head bolt leak. - by dickie65 - 11-06-2018, 05:08 PM
RE: Head bolt leak. - by Ian Williams - 11-06-2018, 09:45 PM
RE: Head bolt leak. - by Michael - 11-06-2018, 11:09 PM
RE: Head bolt leak. - by Graham Honnor - 12-06-2018, 09:30 PM
RE: Head bolt leak. - by Andy Bennett - 12-06-2018, 11:00 PM
RE: Head bolt leak. - by Nick Lettington - 12-06-2018, 11:18 PM
RE: Head bolt leak. - by Speedex750 - 13-06-2018, 04:46 PM
RE: Head bolt leak. - by Graham Honnor - 13-06-2018, 06:25 PM
RE: Head bolt leak. - by Terrytuned - 13-06-2018, 06:58 PM
RE: Head bolt leak. - by Jeff Taylor - 13-06-2018, 07:07 PM
RE: Head bolt leak. - by Colin Morgan - 13-06-2018, 07:35 PM
RE: Head bolt leak. - by Steve Jones - 13-06-2018, 08:01 PM
RE: Head bolt leak. - by Graham Honnor - 13-06-2018, 08:06 PM
RE: Head bolt leak. - by Ian Williams - 13-06-2018, 09:38 PM
RE: Head bolt leak. - by Charles P - 13-06-2018, 09:47 PM
RE: Head bolt leak. - by rubyman - 16-06-2018, 07:41 PM
RE: Head bolt leak. - by Nigel was in Brittany - 16-06-2018, 08:31 PM
RE: Head bolt leak. - by Steve Berg - 28-09-2018, 10:30 AM
RE: Head bolt leak. - by JonE - 28-09-2018, 11:46 AM
RE: Head bolt leak. - by AustinWood - 28-09-2018, 12:00 PM
RE: Head bolt leak. - by Hedd_Jones - 28-09-2018, 01:20 PM
RE: Head bolt leak. - by JonE - 28-09-2018, 02:09 PM
RE: Head bolt leak. - by Hedd_Jones - 28-09-2018, 03:43 PM
RE: Head bolt leak. - by JonE - 28-09-2018, 05:33 PM
RE: Head bolt leak. - by Graham Honnor - 28-09-2018, 04:17 PM
RE: Head bolt leak. - by jansens - 28-09-2018, 08:42 PM
RE: Head bolt leak. - by Graham Honnor - 28-09-2018, 09:21 PM
RE: Head bolt leak. - by Ian Williams - 28-09-2018, 09:26 PM
RE: Head bolt leak. - by Hedd_Jones - 28-09-2018, 09:52 PM
RE: Head bolt leak. - by Colin Reed - 28-09-2018, 10:00 PM
RE: Head bolt leak. - by Chris KC - 29-09-2018, 09:33 AM
RE: Head bolt leak. - by Ian Williams - 29-09-2018, 05:53 AM
RE: Head bolt leak. - by JonE - 29-09-2018, 07:49 AM
RE: Head bolt leak. - by Bob Culver - 29-09-2018, 08:39 AM
RE: Head bolt leak. - by Ian Williams - 29-09-2018, 09:09 AM
RE: Head bolt leak. - by Hedd_Jones - 29-09-2018, 10:43 AM
RE: Head bolt leak. - by carfan - 25-01-2021, 11:32 AM
RE: Head bolt leak. - by Colin Wilks - 25-01-2021, 05:29 PM
RE: Head bolt leak. - by carfan - 25-01-2021, 11:47 PM
RE: Head bolt leak. - by s.earl - 13-06-2022, 10:56 AM
RE: Head bolt leak. - by John Mason - 13-06-2022, 11:41 AM
RE: Head bolt leak. - by Charles Levien - 15-06-2022, 12:52 PM
